Calculating rolling resistance force and coefficient
To compare the rolling resistance of three tire brands, experimental methods are necessary, as theoretical calculations are insufficient. A coastdown test is recommended for accurate measurement, which involves testing a vehicle with all four tires installed under load. Measuring hysteresis can provide insights into rolling losses, but safety considerations are crucial. The impact of tire pressure on rolling resistance is also significant and should be considered. Accurate results can only be obtained through real-world testing under loaded conditions.
boba
I am comparing three brands of tires to see which one provides the lowest rolling resistance and thus give the best efficiency at low speeds. I have the information of the tires such as footprint, weight (of the tire and load), speed.
How would i go about doing this ? am really stumped
thanks
Hello boba, :welcome:
There's no theory that can help you here. You'll need to determine this experimentally.
Hey BvU thanks for the reply, What kind of experiment would you recommend? the size of the tire and load (0.5tone tire and 10 tonne load).
I was thinking measuring the hysteresis and thus getting the loss due to rolling, but i couldn't think of a safe was of doing it.
thanks
Rolling resistance of different tires, and the effect of tire pressure on rolling resistance, is a regular topic of discussion at www.ecomodder.com/forum. There is also information at: https://www.tirerack.com/landing/fuel_efficiency.jsp.
You can measure rolling resistance by a coastdown test, but that requires four tires installed on a car. There are other ways to estimate rolling resistance, but the only way to accurately measure it is on a real road while loaded. That pretty much requires a coastdown test. There is no good way to calculate it from published properties.
Likes boba
Here's a video by “driving 4 answers” who seems to me to be well versed on the details of Internal Combustion engines. The video does cover something that's a bit shrouded in 'conspiracy theory', and he touches on that, but of course for phys.org, I'm only interested in the actual science involved. He analyzes the claim of achieving 100 mpg with a 427 cubic inch V8 1970 Ford Galaxy in 1977. Only the fuel supply system was modified. I was surprised that he feels the claim could have been...
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
