Calculating Second Moment of Aria for Hollow Square Beams
  • Thread starter Thread starter a5hl3yi
    Moment
The second moment of area for a hollow square beam can be calculated by determining the moment of area for the outer solid square and subtracting the moment of area for the inner hollow square. Specifically, for a hollow square beam with an outer dimension of 100mm and an inner dimension of 70mm, the calculation involves finding the moment of area for both squares and using the formula: I = (b*h^3)/12 for the outer square and subtracting the inner square's moment of area. This method ensures accurate results for structural analysis.
  • Understanding of the second moment of area (I)
  • Familiarity with beam theory and structural analysis
  • Knowledge of geometric properties of squares
  • Basic proficiency in calculus for area calculations
  • Research the formula for the second moment of area for various shapes, including hollow sections
  • Learn about the application of the second moment of area in structural engineering
  • Explore software tools for structural analysis, such as AutoCAD or SAP2000
  • Study the differences between solid and hollow beam calculations in engineering contexts
Structural engineers, civil engineering students, and professionals involved in beam design and analysis will benefit from this discussion.
a5hl3yi
Question:
How do you work out the second moment of aria for a hollow square beam?
Attempt:
I have looked over my notes and it says how to get the second moment of aria for all beams but a hollow square one. It has I beam, Circulare beams, Rectangular...
How do you go about working it out for a hollow square beam?
Basically you just take the area moment of a solid square 100mm a side and subtract off the inside.
thanx.
So does that mean I would work out (100mm x 100mm) - (70mm x 70mm) and us that as the aria in the formula or work out the Moment of aria for the 100mm x 100mm and take off the moment of aria for a 70mmx70mm square?
  • · Replies 40 ·
15K
  • · Replies 21 ·
11K
