Calculating Styrene Amount in Liquid/Vapor Phase
  • Thread starter Thread starter sahilk
    Phase
To calculate the amounts of styrene in both the vapor and liquid phases, one needs the mass of styrene, specific volumes of liquid and vapor at the given temperature and pressure, and the tank's total volume. The tank is approximately 65% full with liquid styrene, which is about 50,000 gallons. To find the volume of vapor styrene, the empty volume above the liquid styrene must be considered. Utilizing Raoult's and Henry's laws can provide additional insights for the calculations. Accurate calculations will depend on these parameters and principles.
sahilk
Guys..I once again turn to your help.
There is a certain amount of styrene in a tank at a certain temperature and pressure. i have vapor pressure for styrene at that temp. Can I calculate the amount of styrene in vapor phase and the amount in liquid phase? If so, how?
Thanks.
One would need the mass of styrene, the specific volumes of liquid and vapor at the given temperature and pressure, and the volume of the tank.
I can calculate the mass of liquid styrene. The tank is 50,000 gallons with about 65% full with liquid styrene. Do we need the volume of vapor styrene? or just the empty volume above the styrene. I want to calculate the volume of vapor styrene..so I obviously don't have that.
Check for Raoult and Henry's law, this will help you!
How E-Bike Battery Fires Became a Deadly Crisis in New York City https://www.yahoo.com/news/e-bike-battery-fires-became-120807964.html Do not bring Li batteries into an apartment or occupied structure. They should be stored in non-flammable structures, either metal, brick or cement/concrete. Don't overcharge batteries. Know what to do if one catches fire. Keep them away from flammable materials. Make sure the batteries are not counterfeit. Be cautious of used or damaged batteries.
I have Mass A being pulled vertically. I have Mass B on an incline that is pulling Mass A. There is a 2:1 pulley between them. The math I'm using is: FA = MA / 2 = ? t-force MB * SIN(of the incline degree) = ? If MB is greater then FA, it pulls FA up as MB moves down the incline. BUT... If I reverse the 2:1 pulley. Then the math changes to... FA = MA * 2 = ? t-force MB * SIN(of the incline degree) = ? If FA is greater then MB, it pulls MB up the incline as FA moves down. It's confusing...
Hi. I noticed that all electronic devices in my household that also tell time eventually lag behind, except the ones that get synchronized by radio signal or internet. Most of them are battery-powered, except my alarm clock (which runs slow as well). Why does none of them run too fast? Deliberate design (why)? Wrong temperature for quartz crystal? Decreasing battery voltage? Or just a coincidence?
