Calculating the Average of 2 Functions
  • Thread starter Thread starter dimpledur
    Average Functions
dimpledur
My question pertains to taking the average over a particular period that is composed of 2 functions. For example, from [0, 5ms] the function is defined by 1-e^(-t/1ms)and then by e^(-t/1ms) from [5ms, 10ms].
Will the average from 0-->10 simply be the following:
\bar{f}=\frac{1}{5}\int^{5 ms}_{0}{1-e^{-t/1 ms}}+\frac{1}{5}\int ^{5}_{0}{e^{-t/1 ms}}
If you look at the bottom graph that is orange, it gives visual representation as to what I am trying to take the average of. One period, two functions. One function for half the period, another function for the last half.
Nvm, pretty sure it is as follows:
\bar{f}=\frac{1}{10}\int^{5 ms}_{0}{1-e^{-t/1 ms}}+\frac{1}{10}\int ^{5}_{0}{e^{-t/1 ms}}
Since the entire period is 10, then both contributions from each function needs to be divided by this number. If I hadn't done this, I would not be considering the other half where each function is zero.
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
