Calculating the induced emf in a solenoid, have worked on it, can't get answer
The discussion focuses on calculating the induced electromotive force (emf) in a solenoid with specific dimensions and a decreasing current. The solenoid has a length of 3.7 cm, a diameter of 0.95 cm, and is wound with 160 turns per cm, with the current decreasing at a rate of 38.0 A/s. The formula used for emf is derived from the magnetic flux change, incorporating the permeability of free space, the number of turns, the cross-sectional area, and the rate of current change. Initial calculations yielded an incorrect emf value for one winding and a different result for the entire solenoid when using the wrong number of turns. The discussion emphasizes the importance of correctly applying the turns per length in the calculations.
piperj3
A solenoid of length 3.7 cm and diameter 0.95 cm is wound with 160 turns per cm. The current is decreasing at a rate of 38.0 A/s.
(a) What is the induced emf in one of the windings?
(b) What is the induced emf in the entire solenoid?
emf = -dΦ/dt = μ0N²(A/L) di/dt
Given:
μ0 is the permeability of free space = 4π × 10-7 H/m
N is the number of turns
A is the area where the magnetic flux passes through = π(d/2)²
d is the diameter of the solenoid
L is the length of the solenoid
di/dt is the rate of change in the current
For the first part I set N=1 and for the second I set N=160
4pi * 10^-7 (1)^2 (pi(.95)/2)^2/3.7 (36)
I get 9.15 E-6 which is not the correct answer and for B when I plug in the second set of numbers I get 234 milliamps or .234 amps
Welcome to PF :smile:
What is B for a solenoid? Note that the expression is in terms of the turns per length ... do not simply use N=1 to calculate B.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
