Calculating the Inertia Tensor of a Homogeneous Sphere
The discussion focuses on calculating the moments of inertia for a homogeneous sphere using the inertia tensor formula. An initial attempt yielded an incorrect result of I = (3/5)MR², while the expected answer is (2/5)MR². The integrand was identified as a source of error, specifically the misapplication of variables in the integration process. Suggestions were made to simplify the calculation by focusing on the zz-component of the inertia tensor, which may provide sufficient information for the problem. The conversation emphasizes the importance of correctly setting up the integral and understanding the variables involved.
Storm Butler
Calculate the moments of Inertia I_{1}, I_{2}, I_{3} for a homogenous sphere
I_{jk}=\intx^{2}_{l}\delta_{ik}-x_{i}x_{k}dV
For I_{x} i set up the equation using the above equation in cartesian coordinates and then i switched into polar coordinates and i get the following integral
\rho\int\int\int(r^{2}-rsin(\vartheta)cos(\phi))r^{2}sin(\vartheta)d\phid\varthetadr
with 0\leqr\leqR, 0\leq\phi\leq2\pi, and 0\leq\vartheta\leqpi
when i solve this integral i get I=\rho\frac{4}{5}\piR^{2} and then setting \rho= \frac{M}{4/3\piR^{3}<br /> }
so after simplifying i end up with I=\frac{3}{5}MR^{2}
But the answer i believe is \frac{2}{5}MR^{2} , so i don't really know where is went wrong.
How did you end up with that integral? What are i an k in your expression? Remember that the principal moments of inertia are the diagonal terms in Iij. Start by making the easiest choice for i=j and then think if you have to calculate more.
as i started to type i response i realized my integrand was essentially r^{2}-x. when i should have been r^{2}-x^{2}. So what i should have is r^{4}-r^{4}sin(\vartheta)^{3}cos\phi^{2}
If i integrate this then i get 2/5\pi^{2}R^{5}. which looks better.
although if i then multiply this by rho i get 3/10\piMR^{2}...
That's not right either, one sin(θ) should be in the integration measure. Perhaps it would be easier to calculate only the zz-component of I. Why is this enough?
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
