Calculating the Rate of Mass Falling Over an Area
  • Thread starter Thread starter physiker99
    Mass Time Unit
The discussion revolves around calculating the rate of mass falling over a specified area due to dust particles, incorporating concepts of velocity and density within the context of fluid dynamics or kinematics.
  • Participants explore the relationship between mass, density, area, and velocity, questioning how velocity contributes to the calculation of mass over time. There is an attempt to clarify the dimensional analysis of the involved quantities.
Some participants have provided guidance on the dimensional analysis of the variables involved, suggesting that the relationship holds dimensionally. There is an ongoing exploration of the physical interpretation of the variables and their interactions.
There are indications of typographical errors in the posts, which may affect clarity. The discussion also reflects an assumption that the relationship between density, area, and velocity is understood, but participants are still seeking deeper clarification.
physiker99
Assume there is an area S. Then we have dust particles falling over it having velocity v and density rho.
Is is correct to state mass falling over the S in unit time equals (rho)*(S)*v?
I guess it should be correct, because mass shouldn't have velocity component if none other cancels it.
Welcome to PF!
Hi physiker99! Welcome to PF! :smile:
Yes. :smile:
If you mean that, dimensionally, the 1/L3 in the M/L3 in rho has to be converted to 1/T, then that's correct.
I did a typo there. I don't understand how velocity is used to calculate mass.
It's not purely to calculate the mass. It also determines the rate per unit time through an area S. So you can rewrite S and v as:
[tex]Sv = S\frac{dr}{dt} = \frac{dV}{dt}[/tex]
, with V a volume
The physical interpretation is that a volume V moves through an area S in dt time. See it as moving a cube through a square hole in dt time. The density is defined as mass per volume. So you can rewrite:
[tex]\rho \frac{dV}{dt} = \frac{d\rho V}{dt} = \frac{dM}{dt}[/tex]
, with M the mass
Welcome to PF!
I'll just add this to what D.R. :smile: says:
dimensionally, rho is M/L3, S is L2, and V is L/T
so multiply them all together, and you get M/L3 x L2 x L/T, = M/T, which is mass per time. :wink:
oh, and welcome to PF, D.R.! :smile:
It's understood. Thanks a lot.
  • · Replies 39 ·
  • · Replies 16 ·
  • · Replies 38 ·
