Calculating the speed of an object going down an incline
  • Thread starter Thread starter lull
    Incline Speed
To calculate the speed of an object sliding down an incline, first draw a free body diagram to identify the forces acting on the object, including gravity and friction. The coefficient of static friction determines whether the object will slide; if it's low enough, the object will have a net constant acceleration down the ramp. Using the net force from the free body diagram, calculate the net constant acceleration based on the object's mass. Apply kinematic equations of motion to find the velocity over time, considering the ramp's length and initial conditions. This analysis is crucial for understanding the motion of a bicycle descending the ramp.
lull
Hello, all. How do I find the speed of something going down a ramp if I know the total weight of the object (214 pounds) the angle of the ramp (15 degrees) the frictional coefficient (.0236) the ramp is 11 feet long.
Draw a free body diagram of the object (it's sliding and not rolling, right?, and it is released from rest at the top of the ramp?), showing the forces acting on it (gravity, friction) as vectors, then figure out what motion occurs.
If the coefficient of static friction is high enough, the object will not start sliding. If it isn't high enough, the object will have a net constant acceleration down the ramp. Once you use the FBD to figure out the net force down the ramp, use the object's mass to calculate the net constant acceleration, and use that in the kinematic equations of motion to calculate the velocity versus time for the block.
It is a person on a bicycle going down a ramp. And yes, they are at rest in the beginning.
Also, is it possible if anyone can provide a few formulas? This is for a project but we weren't given any formulas and only given all the information today and it's due tommorow >.<! Thank you all sooo much
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
