Calculating the work against gravity?
  • Thread starter Thread starter mscott
    Gravity Work
To calculate the work against gravity for building a brick tower with a height of 20 feet and a base of 10 feet, the volume of each layer is determined to be 100Δy ft³. The mass of each layer is calculated using the brick's density of 80 lb/ft³, resulting in a force of 78,400 lb acting on each layer. The integral of this force over the height of the tower is computed, but there is a discrepancy with the expected answer in the solutions manual, which states the work should be 1.6x10^6 ft-lb. The correct acceleration due to gravity is clarified as 32 ft/s², which is essential for accurate calculations. This discussion highlights the importance of using the correct gravitational constant in work calculations against gravity.
mscott
Calculate the work against gravity require to build the structure out of brick. Assume the brick has a density of 80 lb/ft^3.
A tower has a height of 20ft and a square base of side 10ft.
This is what I tired to do. I may have gotten it right, but the units or something may have been off. I am hoping one of you will be able to help me.
Volume of layer = 10 x 10 Δy ft^3 = 100Δy ft^3
Mass of layer = 80 lb/ft^3 x 100Δy ft^3
Force on layer = 9.8 x 80 x 100Δy = 78400
Taking the integral of 78400y from limits 0 to 20 equals 15,680,000, but the answer in my solutions manual says the answer should be 1.6x10^6 ft-lb.
Can anyone help me out?
What is the acceleration of gravity in ft/s2?
I'm not sure. Those were the only givens.
I guess you are supposed to know that g = 32 ft/s2. Use that.
