Calculating Time to reach 60 mph
  • Thread starter Thread starter sadhik
    Time
Calculating the time to reach 60 mph requires more information than provided, as factors like friction and aerodynamics must be considered. The discussion suggests using the equations P=E/t and E=1/2*mv², converting units for accurate calculations. Initial velocity is zero, and final velocity is 60 mph, which translates to approximately 26.82 m/s. The weight of the vehicle is noted as 3320 lb, which is interpreted as mass for the calculations. Converting to metric units can simplify the process, allowing for a clearer understanding of power and energy relationships in determining acceleration.
sadhik
In the given table how to calculate the time 0-60 mph(seconds):cry:
ummm, there is certainly not enough information there to calculate a 0-60 time.
unless you're assuming that all power is used 100% efficiently for forward motion and neglect things like friction, gearing, aerodynamics etc etc etc
you could probably roughly use P=E/t and E=1/2*mv², but you're going to have to get some common units.
60 miles = 316800 ft
So initial velocity(u) = 88 ft/sec
Weight = 3320 lb
?Mass(m) = 3320/32 =103.75 lb
?Any chance to get Acceleration(a) from Power:Weight = 0.13554217 hp/lb
?Velocity(v)
well, actually your initial velocity (u) is zero and your final velocity is 60mph
I think they actually mean mass when they say weight in lbs, especially if they're talking about a car, 3320lb mass seems reasonable.
I'm not sure how the US units work so well, so here are the metric standards:
Power - Watts (W)
Energy - Joules (J)
Velocity - metres per second (m/s)
Mass - kilograms (kg)
Force - Newtons (N)
time - seconds (s)
Acceleration - metres per second squared (m/s²)
Try find the equivalent standard units for your unit system or convert everything to metric and try it like I wrote previously.
?Final Velocity(v)=60 mph=3801600 inches/h=96560.8331 m/h=26.8224537 m/s
?Mass(m)=3320 lb=1505.92656 Kg
?Energy=1/2 mv^2=541714.97 Joules
?Power=450 HP=335700 Watts=541714.97 Joules / t
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'What type of toilet do I have?'
I was enrolled in an online plumbing course at Stratford University. My plumbing textbook lists four types of residential toilets: 1# upflush toilets 2# pressure assisted toilets 3# gravity-fed, rim jet toilets and 4# gravity-fed, siphon-jet toilets. I know my toilet is not an upflush toilet because my toilet is not below the sewage line, and my toilet does not have a grinder and a pump next to it to propel waste upwards. I am about 99% sure that my toilet is not a pressure assisted...
After over 25 years of engineering, designing and analyzing bolted joints, I just learned this little fact. According to ASME B1.2, Gages and Gaging for Unified Inch Screw Threads: "The no-go gage should not pass over more than three complete turns when inserted into the internal thread of the product. " 3 turns seems like way to much. I have some really critical nuts that are of standard geometry (5/8"-11 UNC 3B) and have about 4.5 threads when you account for the chamfers on either...
