Calculating Torque & Lever Arm for a Lunch Tray
The discussion focuses on calculating the torque and lever arm for a lunch tray held in one hand, detailing the mass of the tray, food, and coffee cup, along with their respective lever arms. The user initially calculated the force exerted by the thumb but received an incorrect result of -133 Newtons. Suggestions include reviewing the axis of rotation used for torque calculations and ensuring the correct application of static equilibrium equations. Emphasis is placed on the importance of accurately determining the direction of moments and forces. The conversation highlights the complexities involved in torque calculations in a practical scenario.
drewfus
A lunch tray is being held in one hand. The mass of the tray itself is 0.201 kg, and its center of gravity is located at its geometrical center. On the tray is a 1.33 kg plate of food and a 0.285 kg cup of coffee. Assume lever arm of the thumb is 0.0620 m, lever arm of the finger is 0.113 m, lever arm of the plate 0.231 m, lever arm of the coffee cup is 0.361 m and lever arm of the tray is 0.383 m. Obtain the force T exerted by the thumb. This force acts perpendicular to the tray, which is being held parallel to the ground.
The picture that I have (but could not upload for some reason) had the thumb on top of the tray have a force T exerted in the -y direction when drawn with a force diagram and the finger had a +y force.
I plugged into a force table and then calculated a torque table, and I substituted with the two equations and got an answer of -133 Newtons, but I checked it and it was wrong.
Any ideas on what I did wrong?
torque is T=F * D
just take the moment of all forces at one point and then use statics equations to find the rections
From which axis of rotation the arms are measured. Check axis of rotation you have taken and the directions of the moments of force
thanks guys i appreciate it.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
