Calculating Total Energy and Speed of a Ball on a Thread
To solve the problem of a 0.10 kg rubber ball attached to a 0.80 m thread swinging in a vertical circle, the total energy can be calculated using both potential and kinetic energy equations. At the top of the circle, the potential energy is determined by the height above the floor, while at the bottom, the energy remains constant, allowing for the calculation of speed using energy conservation principles. Tension in the thread can be analyzed using centripetal force equations at both the top and bottom of the circle. The horizontal distance the ball travels before hitting the floor can be derived using kinematic equations. Overall, understanding energy conservation and applying relevant physics equations is crucial for solving this problem.
Baumeister41
I need with a problem...A 0.10 kilogram solid rubber ball is attached to the end of an 0.0 meter length of light thread. The ball is swung in a vertical circle. point P, the lowest point of the circle, is 0.20 meter above the floor. The speed of the ball at the top of the circle is 6.0 meters per second, and the total energy is kept constant.
a)Determine the total energy of the ball, using the floor as the zero point for gravitational potential energy.
b)Determine the speed of the ball at point P, the lowest point of the circle
c)Determine the tension of the thread at...
i. the top of the circle
ii. the bottom of the circle
The ball only reaches the top of the circle once before the thread breaks when the bal is at the lowest point of the circle.
d)Determine the horizontal distance that the ball travels before hitting the floor
I'm not sure where to begin.
If anyone can help me it would be great!
The length of the thread is 0.0 m?
You must show some work in the Homework forums. Can you think of anything useful in approaching this problem (relevant equations, etc)?
sry.im new to all of this stuff. the length of thread is 0.80 meters. well for part A i was Thinking PE=m*g*h because it said Potential energy. I get . Part B i think you do .5*m*v^2 = mgh and solve for the velocity. The for C the tension at the top is 0 or (m*g), not to sure on that one. D i can figure out using a kinematic equation
For a), you do need to consider the gravitational potential energy. But the ball is moving, so you need to consider the kinetic energy as well to get the total energy.
For b), since the energy remains constant, the energy at the top of the circle must equal the energy at the bottom of the circle. Since the ball is now closer to the floor, the relation between the potential and kinetic energies change. So just write out the terms for each.
For c), use the idea of a centripetal force with Newton's second law.
For d), yes, you can use kinematics to find the distance.
thank you very much. that was very helpful
Thread 'Help with Time-Independent Perturbation Theory "Good" States Proof'
(Disclaimer: this is not a HW question. I am self-studying, and this felt like the type of question I've seen in this forum. If there is somewhere better for me to share this doubt, please let me know and I'll transfer it right away.) I am currently reviewing Chapter 7 of Introduction to QM by Griffiths. I have been stuck for an hour or so trying to understand the last paragraph of this proof (pls check the attached file). It claims that we can express Ψ_{γ}(0) as a linear combination of...
