Calculating Velocity using Hooke's Law: A Simple Question
  • Thread starter Thread starter unnamedplayer
    Hooke's law Law
The discussion focuses on calculating the speed of a block attached to a spring using Hooke's Law and considering friction. The user is confused about how to determine the total work done on the block, initially attempting to use net force calculations but arriving at incorrect results. It is clarified that the potential energy stored in the spring must be equated to the kinetic energy at the equilibrium point, while also accounting for the work done against friction. The conversation emphasizes that since the spring force is not constant, the work done by each force should be calculated separately and then combined. Ultimately, the importance of applying conservation of energy principles, while considering friction, is highlighted for accurate results.
unnamedplayer
Hi again, all. I thought of another question that I need help with. Again I have the answer but I'm not sure how they got to it. The question is:
A 1.6kg block is supported on a horizontal surface. The block is attached to a sping with k = 1000 N/m. The block compresses the spring x = 0.02 m and is then released from rest. The surface provides 4.00 N constant frictional force. Determine the speed of the block when located at spring's equilibrium point.
Now, I know to use W = (1/2)mv^2 - (1/2)mv^2 to find the velocity but I'm having trouble understanding how they got the total work. What they did was find the work done by the spring on the block and then find the work done by the friction and subtract the two to get the net work done.
But I tried to do it by calculating the spring force (which I got 20N for), subtract the friction so net force is 16 N and then multiply that by the distance 0.02 to get the net work done. But I get the wrong answer and I don't understand why. Maybe I am not calculating the spring force right? I'm using F = -kx.
Any help as to what I'm doing wrong would be greatly appreciated!
maybe you need to take in consideration acceleration due to gravity?
the mass 1.6 would be acted upon by gravity when it is let go right? so there you have downwards force
Force isn't constant. You'll need calculus to solve it that way.
Potential energy of a spring:
E = \frac{1}{2}kx^2
It's directed downwards. But then there's the support force of the surface upwards, which is equal but opposite to the force caused by gravity. Thus we only need to consider horizontal motion.
So if the force isn't constant I have to find the work done by each force then add or subtract them to get the net work? Otherwise if the force is constant I can use the method I tried using in which I just find the net force and then multiply by the distance to find the work right?
As Päällikkö was trying to say (I think) you don't have to workout the individual forces, just the energies. In the initial position there is only potential energy from the spring, at the equilibrium there is only kinetic energy so you can write that:
\frac{1}{2}mv_{f}^2 = \frac{1}{2}kx_{i}^2
I don't think so Daniel, you're applying the Conservation of energy without taking care of friction.
\Delta E = W_{friction}
Sorry, I didn't notice the friction.
