Calculating Voltage from Electric Field between Parallel Plates
The discussion revolves around calculating the voltage between two parallel plates affecting a stream of electrons, initially accelerated by a 1 kV voltage. The electric field is calculated to be 50,000 V/m, and using the equations provided, the voltage between the second set of plates is derived to be approximately 34.1 V. Further recalculations involve determining the velocity and acceleration of the electrons in both x and y directions, leading to a final voltage of about 107.2 V. The calculations and methodologies presented are generally validated by participants in the discussion. The thread emphasizes the importance of understanding the relationship between electric fields, voltage, and the motion of charged particles.
mmoadi
Electrons, which evaporated from the filament accelerated in homogeneous electric field that was created by using two parallel metal plates, connected to the voltage
V = 1 kV. The resulting stream of electrons is deviated from the initial direction for a
φ = 15 ° in electrical field between two parallel flat surfaces. The length of the plate, in the direction of the initial movement of electrons, is s = 10 cm and the distance between the plates is d = 2 cm. What is the voltage V' between the two plates?
E= V/d
ΔV= V’ – V
ΔV= -E*d*cos φ
E= V/d
E= 1000 v/ 0.02 m
E= 50000 V/m
ΔV= -E*d*cos φ
V’ – V= -E*d*cos φ
V’ – 1000 V= -50000 V/m*0.02m*cos15º
V’= -965.9 V – 1000 V
V’= 34.1 V
Are my calculations correct?
Thank you for helping!
You have two sets of plates. The first one is used to accelerate the electrons. The 1kV is applied between the plates in this first set.
The second set is used to deviate the electron beam. You need to calculate the volatge between these two.
The first voltage (1KV) is given so that you can calculate the initial speed of the electrons before they enter the second set of plates.
:biggrin:RECALCULATION:
F= m*a
E= U/d
W= ΔKE
- First I solved for vector velocity in the w-direction:
W= F*d= q*U
W= KE’ – KE0 ≈ 0
q*U= m*v(x)²/ 2
v(x)²= 2q*U/ m
v(x)= sqrt[2q*U/ m]
- Now I solved for acceleration in the y-direction:
a(y)= F(y)/ m
F(y)= E(y)*q
F(y)= (U’/d)*q
a(y)= (U’*q)/ (d*m)
- Now velocity in the y-direction:
v(y)= a(y)*t
s= v(x)*t → t= s/ v(x)
v(y)= (U’*q/ d*m)/ s/v(x)
v(y)= U’*q*s/ d*m*v(x)
tan φ= v(y)/ v(x)
tan φ= (U’*q*s/ d*m*v(x))/ v(x)
tan φ= (U’*q*s)/ (d*m*v(x)²)
tan φ= (U’*q*s*m)/ (d*m*2q*U)
tan φ= (U’*s)/ (2d*U)
U’= (tan φ*d*2U)/ s
U’= 107.2 V
Thank you for helping!:smile:
It looks OK to me.
Thank you for helping:smile:!
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
