Calculating Wavelength of Light in Glass Slab
  • Thread starter Thread starter sghaussi
    Light Propagation
To calculate the wavelength of light in a glass slab, first determine the time light takes to travel through air and glass. The initial wavelength of light in air is 560 nm, and the travel times are 16.5 ns in air and 21.3 ns with the glass slab. The thickness of the glass slab (0.860 m) is crucial for calculating the speed of light in the glass, as it affects the overall travel time. By using the speed of light in a vacuum (3×10^8 m/s) and the respective travel times, one can derive the speed of light in the glass and subsequently find the wavelength. Understanding these relationships is essential for solving the problem accurately.
sghaussi
Hi! I was wondering if you can give me some adivice on how to approach this problem:
In a physics lab, light with a wavelength of 560 nm travels in air from a laser to a photocell in a time of 16.5 ns. When a slab of glass with a thickness of 0.860 m is placed in the light beam, with the beam incident along the normal to the parallel faces of the slab, it takes the light a time of 21.3 ns to travel from the laser to the photocell.
What is the wavelength of the light in the glass?
Use 3×108 m/s for the speed of light in a vacuum.
My main problem is that I don't know how the thickness of the medium is important.
Thank you in advance,
Sahar
how long did the light take to travel the glass?
thats when the thickness counts
you can get your index once you figure this out
as the light goes through the glass, the frequency doesn't change just the wavelength
what does this tell you?
The first thing to do is to find how long the original path is.
s_0 = c\Delta t_0
For the path through the glass, there are two parts:
s_{air} = c\Delta t_{air} and
s_{glass} = v_{glass}\Delta t_{glass}
so you know, or can work out: s_{air},\Delta t_{air}, s_{glass}, \Delta t_{glass}
From that you should be able to work out v_{glass} and wavelength follows from that.
AM
