Calculating Work and Kinetic Energy in a Two Mass Pulley System
The discussion revolves around a two mass pulley system where the original poster seeks to calculate the work done by gravitational forces and the kinetic energy of the masses involved. The problem involves concepts from mechanics, specifically work, energy, and motion in the presence of friction.
  • The original poster attempts to relate work done to changes in potential and kinetic energy, questioning how to express these relationships accurately.
  • Some participants suggest specific formulas for work and acceleration, while others question the assumptions regarding the work done by gravity on both masses.
  • There is discussion about the effects of friction and how it alters the calculations for acceleration and velocity.
  • Participants express uncertainty about the implications of their calculations on the kinetic energy distribution between the masses.
Participants are actively engaging with the problem, providing insights and corrections to each other's reasoning. Some guidance has been offered regarding the correct application of work and energy principles, but there remains a lack of consensus on certain aspects, particularly regarding the distribution of kinetic energy and the role of friction.
There are constraints related to the assumptions made about friction and the mass of the pulley and rope, which are noted but not resolved. The original poster's attempts indicate a need for clarification on the fundamental principles involved.
Diego Cunha
https://int.erlace.com/uploads/teacher/1533/images/3modifiedatwood(1).jpg
Ignore friction and the the rope and the pulley and the rope have negligible mass.
  1. When the hanging block
    has descended a distance
    , how much work has the gravitational force by the Earth done on the system?
  2. That work went into the kinetic energy of the masses. What fraction of that kinetic energy went into the motion of the hanging block?
  3. Suppose now there's a coefficient of kinetic friction
    between
    and the table surface. Find the speed of the masses when
    has descended that distance
1. I figured the work done was equal to change in potential energy, so
2. I'm not sure how to go about this one. I tried to take what I found for the work done and relate it the kinetic energy of the masses, so something like
7B1%7D%29gh%20%3D%20%5Cfrac%7B1%7D%7B2%7Dm_%7B2%7Dv%5E2+%5Cfrac%7B1%7D%7B2%7Dm_%7B1%7Dv%5E2.gif
, but I don't know if this would help, or if it is right at all.
3. Not sure. I derived an expression for acceleration of the system, and again I don't know if it would help.
gif.latex?a%3D%5Cfrac%7Bm_%7B2%7Dg-%5Cmu%20m_%7B1%7Dg%7D%7Bm_%7B2%7D+m_%7B1%7D%7D.gif
Thanks.
Looks like two pictures didn't post
For part 1, (m1 + m2)gh
For part 3, a = (m2g - μm1g)/(m1 + m2)
Your solution :
(1.) is wrong .
Does gravity do work on both blocks ?
*Remember - Work done is ∫F.dx
(2.) - What is acceleration of each block ? So what is velocity after moving a distance Δh ?
(3.) - Repeat as previous part .
I hope this helps .
You got that part right.
Qwertywerty said:
Your solution :
(1.) is wrong .
I hope this helps .
Yes, this helps. Gravity would only do work on m2 so the work done would be equal to m2gh. The acceleration of the blocks are the same, so each would have an an acceleration a = (m2g)/(m1+m2 ), without friction. For the m2, the velocity would be (m2v2)/2 = m2gh, so v = √(2gh). Does this tell me anything in terms of how much kinetic energy went into moving m2, would it be all of it?
I think my expression for velocity was wrong, since I didn't account for m1, it would be v=√2h(m2g)/(m1+m2 )
  • · Replies 22 ·
  • · Replies 22 ·
  • · Replies 30 ·
  • · Replies 17 ·
