Calculating Work and Kinetic Energy in a Two Mass Pulley System
The discussion focuses on calculating work and kinetic energy in a two-mass pulley system, specifically addressing the work done by gravitational force on the hanging block and its relationship to kinetic energy. Initially, it was suggested that the work done equates to the change in potential energy, but it was clarified that gravity only does work on the hanging mass, m2, resulting in work equal to m2gh. The acceleration of both blocks is the same, calculated as a = (m2g)/(m1 + m2) when ignoring friction. The correct expression for velocity after descending a distance is v = √(2h(m2g)/(m1 + m2)). The discussion emphasizes the importance of accurately accounting for both masses in calculations of kinetic energy and velocity.
Diego Cunha
https://int.erlace.com/uploads/teacher/1533/images/3modifiedatwood(1).jpg
Ignore friction and the the rope and the pulley and the rope have negligible mass.
  1. When the hanging block
    has descended a distance
    , how much work has the gravitational force by the Earth done on the system?
  2. That work went into the kinetic energy of the masses. What fraction of that kinetic energy went into the motion of the hanging block?
  3. Suppose now there's a coefficient of kinetic friction
    between
    and the table surface. Find the speed of the masses when
    has descended that distance
1. I figured the work done was equal to change in potential energy, so
2. I'm not sure how to go about this one. I tried to take what I found for the work done and relate it the kinetic energy of the masses, so something like
7B1%7D%29gh%20%3D%20%5Cfrac%7B1%7D%7B2%7Dm_%7B2%7Dv%5E2+%5Cfrac%7B1%7D%7B2%7Dm_%7B1%7Dv%5E2.gif
, but I don't know if this would help, or if it is right at all.
3. Not sure. I derived an expression for acceleration of the system, and again I don't know if it would help.
gif.latex?a%3D%5Cfrac%7Bm_%7B2%7Dg-%5Cmu%20m_%7B1%7Dg%7D%7Bm_%7B2%7D+m_%7B1%7D%7D.gif
Thanks.
Looks like two pictures didn't post
For part 1, (m1 + m2)gh
For part 3, a = (m2g - μm1g)/(m1 + m2)
Your solution :
(1.) is wrong .
Does gravity do work on both blocks ?
*Remember - Work done is ∫F.dx
(2.) - What is acceleration of each block ? So what is velocity after moving a distance Δh ?
(3.) - Repeat as previous part .
I hope this helps .
You got that part right.
Qwertywerty said:
Your solution :
(1.) is wrong .
I hope this helps .
Yes, this helps. Gravity would only do work on m2 so the work done would be equal to m2gh. The acceleration of the blocks are the same, so each would have an an acceleration a = (m2g)/(m1+m2 ), without friction. For the m2, the velocity would be (m2v2)/2 = m2gh, so v = √(2gh). Does this tell me anything in terms of how much kinetic energy went into moving m2, would it be all of it?
I think my expression for velocity was wrong, since I didn't account for m1, it would be v=√2h(m2g)/(m1+m2 )
A Full Stack Development Program prepares students to create end to end web applications using front end as well as back-end technologies. The purpose is to get experience in creating user interfaces, managing databases, and conducting server-side activities, resulting in a thorough understanding of how web platforms work. This skill is essential since it allows developers to participate at every step of a project, enhancing critical thinking and productivity. registering in Full Stack...
