Calculating Work and Mechanical Energy - Block on Ramp
A 5.0 kg block slides down a 30-degree incline, and the discussion focuses on calculating the work done by gravity, the mechanical energy lost to friction, and the work done by the normal force. The gravitational potential energy was calculated to be 61.31 J, while the kinetic energy at the bottom of the incline was found to be 15.625 J. The energy lost due to friction was determined to be approximately 47.685 J. The participants discussed the importance of breaking down forces into components and using basic physics equations to solve the problem. The conversation highlights the challenges of understanding these concepts and the need for clear problem-solving strategies.
mimib1230
Starting from rest, a 5.0 kg block slides 2.5 m down a rough 30.0 degree incline in 2.0 seconds. Determine the following:
a. work down by the force of gravity
b. the mechanical energy lost due to friction
c. the work done by the normal force between the block and the incline
I think Wnet = Fnetd(cos thata) is relevant.
KE = 1/2mv^2
and PEg = mgh
I started by drawing a force diagram...49.1 N pointing downards and a 30 degree angle drawn in. I know that I need to figure out Forcenet but I'm not sure how. I would attempt more of a solution but I'm honestly just that bad at physics. I've worked all week and I have an exam on Friday, but I'm still clueless. Help is really needed here. I want to understand.
Hi mimib1230. Welcome to PF.
Try starting by spliting the weight of the mass into components. From this you'll have a force down the slope (but which one?) and this will then allow you to substitute the value into an equation (but which one?). See what you make of that. I will not give you anymore as I read that you want to understand. Small hints at a time. :biggrin:
The Bob
Fparallel = Fgsin30 = (49.1 N ) sin 30 = 24.6 N
Ffriction? I don't have the coefficient of friction, so how can I figure out my Fnet?
Because you know the force needed to overcome friction down the slope and also the normal reaction so could work out the coefficient of friction. However, you don't really need this to work it out. As you know the other information in your question you can find the work done by comparing initial and final answers to this problem.
The Bob
A lot of the time, I don't know exactly where to start (at all). My instinct here was to draw a force diagram, figure out friction, do a billion different things to get Forcenet.
But actually I asked my teacher and all I needed was to draw a triangle to figure out the height for part A.
So h= 1.25 from the ground because 2.5sin30 = 1.24 m.
PEgravity = (5.0 kg)(-9.81 m/s/s) (-1.25 m) = 61.31 J
delta x = 1/2 (vi + vf) time
-2.50 m = 1/2 (vf) (2.00 s)
vf = 2.5 m/s
KE = 1/2 (5.0 kg) (-2.5 m/s)2 = 15.625 J
PEgravity - KE = energy lost due to friction
so
61.31 J - 15.625 J = 47.685 J
Is part C simply "no energy?" It is only moving up and down via the path of the incline, not through the air, right?
hello, i have a question kinda like that but different.
it says a football player pushes a box that wieghs 300n up a ramp that is 6 meters long with a force of 150n while the person on the box is 3 meters high. what is the actual work done?
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
