Calculating work done by E field/voltage
  • Thread starter Thread starter xcvxcvvc
    Work Work done
The discussion revolves around calculating the external work needed to bring a charge of -5 microC from infinity to the center of a square formed by four point charges. The initial calculations led to a discrepancy, with one participant arriving at -1.28 J while the book stated -2.55 J. Key points include the need to correctly determine the distance from the center to the corners of the square, which is 0.05 m rather than 0.1 m. The correct approach involves calculating the potential energy at the center by summing the contributions from each charge and applying the work formula. Ultimately, the error was identified as a miscalculation of the distance, leading to the realization that the factor of two difference was due to this oversight.
xcvxcvvc
Four point particles with charges .6 microC, 2.2 microC, -3.6microC, and 4.8 microC are placed at the corners of a square of side 10cm. what is the external work needed to bring a charge of -5 microC from infinity to the center of the square? (Assume the speed of the -5 microC charge is kept constant)
V=kq/r(from infinity)
w = Q * v
Vtotal = V1 + v2...Vn
9x10^9 * (-5 x 10^-12) / squareroot(.1^2 + .1^2) * (.6 + 2.2 - 3.6 + 4.8) = -1.28 J
answer in book: -2.55J
my answer is nearly a perfect factor of 2 away. What's going on here?
I'm not too sure what you did in your calculations but..
First step is to do a diagram with the 4 charges each at a corner of the square. Then you have to find the potential energy at the center of the square (which is acquired by adding the V=kq/r for each charge). Now that you have the potential energy at the center of the square you can just apply w=qv to get the correct answer.
that's what i did, and there is no need for a diagram due to the simplicity of a cube
let me explain my calculations: w = k Qq/r
i factored the k out, i factored the r out, and the Q(the charge brought to the middle) is also factored out. I also factored out a x10^-6 (the -12 comes from that), so all that is left is the sum of the charges on the corner.
your method is fine, you must have done a calculation error somewhere. just redo it on a piece of paper.
I have! Could you do it yourself to confirm my answer? Erroneous book answers are not unheard of.
yeah, I had just done it and I got -2.55J as the answer right before I posted my reply. here:
W=(kQq)/r
get it into W=(k)*(Q)/(r)*(sum of qs) form
W=(9*10^9)*(-5microC)/(0.0707m) *(.6microC + 2.2microC - 3.6microC + 4.8microC)
W=-636396*(4microC)
W=-2.55J
I'm kind of sleepy so i couldn't pinpoint the problem earlier but I'm pretty sure you just used the wrong value of r, that's why I recommended to draw a diagram. its the middle of a square with 10 cm sides so if you do pythagoras you have to use .05m and not .1m like you did
omg... of course. a factor of two was no coincidence! I forgot to divide my length by two!
