How is the Calorimetry Mixture Problem Calculated?
The discussion revolves around a calorimetry problem involving the heat transfer between lead and water. The user is confused about the calculation of heat (q) for lead, specifically why the formula uses the initial temperature of lead (100°C) and the final temperature of the mixture (22°C) to determine the change in temperature (ΔT). The correct formula for heat transfer is q = mcΔT, where ΔT is calculated as Tfinal - Tinitial. In this case, the calculation for q(lead) is correct, as it reflects the heat lost by the lead, resulting in a negative value, which indicates that the lead is losing heat to the water. This aligns with the principles of thermodynamics, where heat flows from the hotter substance (lead) to the cooler one (water), ultimately resulting in a final temperature that is lower than the initial temperature of the lead.
Bashyboy
Hello, my problem is as follows: " If 150 g of lead at 100°C were placed in a calorimeter with 50 g of water at 28.8°C and the resulting temperature of the mixture was 22°C, what are the values of q(lead), q(water), and q(cal)? (Knowing that the specific heat of water is 4.184 J/g °C and the specific heat of lead is 0.128 J/g °C)
The part that I don't understand in the calculations is this:
q(lead) = 0.128 J/g °C x 150g x (28.8°C - 100°C) = -1.37 E3 J
Why do they subtract 100 from 28.8? From my present understanding, 100 degrees is the initial temperature of the lead and 28.8 degrees is the initial temperature of water; shouldn't they subtract 100 degrees from 22 degrees?
Thank you.
Chemistry news on Phys.org
No way putting hot lead in a warm water can yield a mix colder than initial temperatures of both substances.
q is mcΔT, where ΔT=Tfinal-T[/sub]initial[/sub], so at least the second part (-100) is correct. It yields a negative q, meaning lead lost heat - that also makes sense, and fits the convention.
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
I was introduced to the Octet Rule recently and make me wonder, why does 8 valence electrons or a full p orbital always make an element inert? What is so special with a full p orbital? Like take Calcium for an example, its outer orbital is filled but its only the s orbital thats filled so its still reactive not so much as the Alkaline metals but still pretty reactive. Can someone explain it to me? Thanks!!
I'm trying to find a cheap DIY method to etch holes of various shapes through 0.3mm Aluminium sheet using 5-10% Sodium Hydroxide. The idea is to apply a resist to the Aluminium then selectively ablate it off using a diode laser cutter and then dissolve away the Aluminium using Sodium Hydroxide. By cheap I mean resists costing say £20 in small quantities. The Internet has suggested various resists to try including... Enamel paint (only survived seconds in the NaOH!) Acrylic paint (only...
