Solving for cx: Specific Heat of Material X | Calorimetry Question
  • Thread starter Thread starter davekardle
    Calorimetry
To find the specific heat (cx) of material X, a calorimetry problem involves 75g of X in a copper calorimeter with 65g of water, all initially at 20°C, and the addition of 100g of water at 80°C, resulting in a final temperature of 49°C. The calculations involve determining the energy exchanges between the materials using the formula Q=mcΔT. Initial attempts yielded cx values of 2.18 kJ and 1.97 kJ, but discrepancies arose in the energy balance and mass calculations. Clarifications were sought regarding the treatment of different materials and the use of a zero-energy reference point. The discussion emphasizes the importance of correctly accounting for all energy contributions to solve for cx accurately.
davekardle
To find cx, the specific heat of material X, I place 75g of X in a 30g copper
calorimeter that contains 65g of water, all initially at 20°C. When I add 100g of
water at 80°C, the final temperature is 49°C. What is cx?
Data: cCU = 386 J kg
-1
K
Q=mcDt
I tried finding out the amount of energy around in the system of water and cupper and then added the energy provided by the addition of X, with its variable Cx.
I then added the energy provided by the 100g of water at 80. and equalled that to the ( Sum of masses x Cw x Cc x Cx x 49. and then tried to calculate the variable Cx by rearranging. The answer is 2.18 Kj. I can't find it :(
welcome to pf!
hi davekardle! welcome to pf! :wink:
show us what you've tried, and then we'll know how to help! :smile:
Energy Available in the system ( H2O + Cu)
Q= 0.03 x 0.386 x 20 = 0.2316 KJ (Cu)
Q= 0.065 x 4.2 x 20 = 5.5
total Qw + Qcu = 5.7 Kj KG- C-
ENERGY offered by X:
Q= 0.075x Cx x 20= 1.5Cx
Energy offered by water:
Q= 0.1 x 4.2 x 80 = 33.6 Kj Kg- c-
ADDING energies=
5.5 + 1.5Cx + 33.6 = 0.170kg(TOTAL mass of mix) x (0.27 x 4.2) x Cx x 49 ( final temp)
rearranging
39.3 = 19.9Cx
Cx= 1.97Kj
Which is wrong :(
i don't understand this bit …
(what is the 0.27 ? and …)
don't you need to continue to treat each of the materials separately?
(btw, you've used a "zero-energy-level" of 0° …
it would be easier and quicker to use 20°)​
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
