Can a coefficient value change? help
The discussion centers on the determination of the coefficient of friction when pulling an object up an inclined ramp. It highlights the relationship between the applied force (Fa), the normal force (Fn), and the gravitational force components as the incline changes. The formula for the coefficient of friction (u) is derived from the forces acting on the object, emphasizing that Fa is not equal to the frictional force (Ff) on an incline. The conversation also questions whether the coefficient value can change when pulling an object versus allowing it to slide down. Ultimately, the conclusion suggests that the coefficient should remain consistent regardless of the angle of the incline.
northern expo
this is a similar question to an earlier queestion but an interesting relationship occured.
when finding an experiemental coefficient of friction between a brick and a wooden ramp we can determine this coefficient by applying a measureable force at a constant velocity and the weight of the object ( u = fa / fg ) where the fa is theforce parallel and fg is the force normal. no problem with this but as the ramp is elevated (creating an incline) and we look at the force parallel required to pull it up the ramp at a constant velocity and the force normal (cos angle x fg ) this relationship appears to an increasing value due to the increasing fa and a decreasing fn. is there something I'm missing or can i not find a coefficient value by pulling up an incline and only when allowing it to slide down the ramp?
I'm sure there is something simple I'm missing. any help?
also is there a standard value between wood and concrete?
There is more to the story than fa/fg when the ramp is inclined.
Ff = u Fn
u = Ff/Fn
Fn is mg cos(angle)
Ff is not equal to Fa like it was for the horizontal surface. Now Fa is being opposed by a part of Fg and Ff.
So we do a summation of forces along the path of motion (up the ramp) and set it equal to zero:
Fa - Ff - Fg sin(angle) = 0
Ff = Fa - mg sin(angle)
u = Ff/Fn = [Fa - mg sin(angle)]/[mg cos(angle)]
It should give you the same answer no matter what the angle is.
I think it's easist first to watch a short vidio clip I find these videos very relaxing to watch .. I got to thinking is this being done in the most efficient way? The sand has to be suspended in the water to move it to the outlet ... The faster the water , the more turbulance and the sand stays suspended, so it seems to me the rule of thumb is the hose be aimed towards the outlet at all times .. Many times the workers hit the sand directly which will greatly reduce the water...
comparing a flat solar panel of area 2π r² and a hemisphere of the same area, the hemispherical solar panel would only occupy the area π r² of while the flat panel would occupy an entire 2π r² of land. wouldn't the hemispherical version have the same area of panel exposed to the sun, occupy less land space and can therefore increase the number of panels one land can have fitted? this would increase the power output proportionally as well. when I searched it up I wasn't satisfied with...
