Finding Angle of Refraction with Given Angles
rhxoehwhfh
does anybody know formula for finding angle of refraction with given angles of incidence in the medium and the angle of refraction?
I might try looking http://hyperphysics.phy-astr.gsu.edu/hbase/hframe.html"
Casey
Snell's law. Again.
