Can Converting Secant to Cosine Simplify Integration by Parts?
AStaunton
problem is to integrate the following by parts:
\int x\sec^{2}xdx
my feeling is convert the secant term to cosine by:
sec^{2}x=cos^{-2}x\Rightarrow\int\sec^{2}xdx=\int\cos^{-2}xdx
then:
u=\cos^{-2}x\implies du=2\sin x(\cos^{-3}x)
and also:
dv=xdx\implies v=\frac{x^{2}}{2}
however plugging all this into int. by parts equation ends up with:
\frac{x^{2}}{2}\cos^{-2}x-\int2\frac{x^{2}}{2}\sin x\cos^{-3}xdx
which seems to be an even more complicated integral...
is my idea of converting the secant to cosine a good or does it make more complicated?
any advice appreciated
I wouldn't convert the secant term at all. Remember that sec2 x is the derivative of some trig function.
While recognizing the antiderivative of sec^2(x) is the real key to this problem, many times it will make the problem easier if you can eliminate the polynomial portion by choosing that as your u.
In this case: both of these ideas will work together.
\text{Let: }u=x\quad\text{ and let: }\quad dv=\sec^2(x)\,dx\ .
This works out nicely!
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
