Can I hardwire 12v light to my 110v house wires?
  • Thread starter Thread starter greggo
    12v Light Wires
Hardwiring 12V LED lights to 110V house wiring requires a transformer to convert the voltage. If the lights need a DC supply, a 110VAC to 12VDC transformer is necessary. It's important to ensure the transformer can handle the current required by the LED lights. Hardwiring can void home fire insurance if not done by a licensed electrician, so using a plug-in transformer is recommended for safety. Proper equipment and caution are essential when modifying electrical systems.
greggo
I have a strand of 12v led lights that I'd like to use as under mount lights for my kitchen cabinets. Is there a way to hook the lights up to my existing 110v wiring assuming there is a converter necessary?
do the LED light units require an AC or DC supply ?
they are available in both versions
if AC, then you would need a 110V to 12V transformer plug pack ( wallwart)
if DC then a 110VAC to 12VDC transformer plug pack ( wallwart)
have you got a link to the type of LED light units you have so we can make a more informed response ?
cheers
Dave
It requires a DC12V input. Before, I used a 9V wall plug, but now I'm wanting to hard wire them. So I guess I need the 110VAC to DC12V transformer?
Yep. Just look for the DC 12V output wall transformer that has a high enough output current rating to supply the needed current to your LED string.
Perfect. Thank you.
I assume you are not a licensed electrician so anything you hard wire into your mains supply will void your home fire insurance. Best to stick with a plug in tranny
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
