Can period of such signal be found.
  • Thread starter Thread starter John Atkinson
    Period Signal
The discussion focuses on determining the periodicity of two combined square wave signals with different periods. It emphasizes that the signals will be periodic if their periods are in a whole number ratio, which in this case is √6:1/√6, resulting in a ratio of 6. The conversation suggests using voltage instead of current for easier calculations, recommending tools like LTSpice for practical experimentation. Participants advise drawing the waveforms to visualize the combined signal, which will oscillate between 0 and 2 volts. Overall, understanding the relationship between the periods is crucial for determining the resulting signal's periodicity.
John Atkinson
How to find the period of two signals added for example:
if f= s1+s2 where s1 is a squre wave of (+ -) 1 A, period √6 secs and s2 is a square wave of (+ -) 1 A, period 1/√6 secs.
Is this signal periodic if not why?
Can anyone let me know about some link where I can learn all the examples of such type.
]The signals will have a repeating (periodic) pattern if their periods are in a whole number ratio to each other.
So, you have a ratio of √6 divided by 1/√6. That is √6 times √6. Or 6.
It is easier to work this out if you use voltage instead of current. To add voltages, you can just put two voltage generators in series.
However this seems like homework, so you need to make an effort to do some of it yourself. (Them's the rules!)
I suggest you get a free copy of LTSpice and use this to work out these oddball problems.
There will be one square wave that is faster than the other.
So draw it out on paper.
The slower square wave goes to 1 volt and then has the faster one imposed on it, so the result is a sqaure wave between 0 volts and 2 volts.
Then the slow wave goes to -1 volt and the same thing happens, except from -2 volts to zero volts.
http://dl.dropbox.com/u/4222062/2%20sq%20waves.PNG
It is not HW it is just one of the questions in class presentations for which I am curious to know how to find the period of the signal theoretically. Can you suggest me some book.
As you suggested about the signal to be voltage can you explain the same assuming it to be voltage. How to find the period as I want to clear my doubts.
If you look at the diagram above, you will see that the period is the same as that of the lowest frequency square wave.
Once you establish that the two waveforms have a whole number relationship, then you can say this.
I can't suggest a book, but I think a piece of graph paper would be more useful.
Just draw the two waveforms and then go along and add them to get a graph like the one above.
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
