Can someone help explain me a problem?
  • Thread starter Thread starter xdrgnh
    Explain
A sphere with radius R has a uniform surface charge Q, and the problem asks for the radius of a sphere that contains 90% of the electrostatic energy stored in the field. The energy to assemble a shell is derived as Q^2/2R, leading to confusion about whether the sphere is hollow or solid. Clarification suggests that the sphere refers to a Gaussian surface surrounding the charged sphere, not a physical shell. The focus is on calculating the energy in the initial sphere and determining the new radius that encompasses 90% of that energy. The discussion concludes with an understanding of the problem's requirements and an intention to finalize the solution.
xdrgnh
A sphere of radius R has a charge Q distributed uniformly over its surface. How large
a sphere contains 90 percent of the energy stored in the electrostatic field of this charge
distribution?
U= 1/8pi integral E^2dv.
I was able to derive that the energy to assemble a shell is Q^2/2R. The problem is idk what kind of sphere they are talking about? Do they mean a hollow sphere or one with a charge density?
I think they mean solid sphere because otherwise they would say hollow sphere in the question.
So you have to compute the energy in the initial sphere, take 90% of it and then use it to get a new radius, right?
I guess it is a solid one. The thing that confused me was that the initial sphere has to be hollow because there is no charge density on the inside just on the surface. Thus I know I can treat that as a shell.
Solid or hollow the charge is on the surface only.
It could be that they mean what size of a spherical volume of space surrounding the charged sphere contains 90% of the energy of the field. So the "sphere" would be insubstantial, like a Gaussian surface, a designated boundary.
I think I understand now thanks a lot gneill I'll post my answer tmr. I'm pretty tired from working all day.
