Can someone just check if I did this line integral correctly?
ainster31
$$\int _{ 0 }^{ 2\pi }{ xdx } \\ =-\int _{ 0 }^{ 2\pi }{ sintcostdt } \\ =0$$
It feels wrong.
I got zero also using a different method. Let's review the steps. You said
x = cos t, dx = -sint dt and t now runs from 0 to 2##\pi##.
Since cost and sint are both periodic in 2##\pi## you got zero.
What may feel wrong is that ##\int_0^{2\pi}x dx## is not zero. However, this is not the same thing as integrating x around a circle. Basically you are running cos(t) around that circle, and it's going to start and end with the same value.
Notice that x is positive on the right side of the circle, negative on the left side of the circle. The two halves cancel, leaving 0.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
