Can the Normal Force Produce a Torque on an Object on an Incline?
The discussion centers on whether the normal force can produce torque on an object on an incline. Participants express confusion about how the normal force, acting perpendicular to the surface, could create torque, particularly in the case of a block. It is noted that the presence of friction affects the distribution of normal force, potentially leading to a net torque. The conversation also touches on internal stresses and how they relate to torque, with some suggesting that torque can exist due to non-uniform distribution of normal force in certain shapes. Ultimately, the consensus is that while normal forces typically do not produce torque, specific conditions like friction can alter this outcome.
rashida564
Hi everyone I can't understand how normal force produce torque isn't normal force acts normally on the plane so the perpendicular distance in case if it was like block will be zero, so normal force doesn't produce torque. "case of box"
I don't have any idea what you are describing here. Can you please provide a diagram?
rashida564 said:
Summary:: Normal force producing torque on inclines.
Are you referring to internal stress?
Is all normal force haze zero torque
Depends on the friction I think
Here's a geometry question for you: If you have a line tangent to a circle, the normal to the line at the point of tangency passes through the center of the circle. True of False.
Yes
But why square shapes get torque from normal forces
Please provide a diagram for square shapes.
Square
rashida564 said:
Square
Who says that the normal force results in a torque about the center of the square?
How square in friction surface have net torque of zero
Internal "torques" exist in the form of stress.
But internal torques comes in pair so they cancel each other
As @dsaun777 indicates, if friction is present, the normal force is not distributed uniformly over the base of the square, and the normal stress is greater near the downward edge than near the upper edge on the base.
