Can the pressure of liquid air/gas can be increased?
  • Thread starter Thread starter pranj5
    Liquid Pressure
The pressure of liquid air or gas can be increased mechanically by either adding more fluid to a fixed-volume container or by reducing the container's size with a fixed mass of fluid. This can be achieved using high-static-pressure pumps for continuous flow or piston-cylinder systems for compressing the fluid. Cryogenic pumps are suitable for handling fluids at low temperatures, although the discussion raises concerns about machinery performance at these temperatures. It is clarified that liquid water does not represent a very low temperature, suggesting that the focus should be on specific cryogenic applications. Understanding the practical machinery options is essential for effectively increasing the pressure of liquid air or gas.
pranj5
I want to know whether like liquid water or other liquids available at normal temperature and pressure, can the pressure of liquid air/gas be increased mechanically? If yes, then what kind of machinery can do the job? I am asking the question here not on the theoretical part, but on the practical aspect.
Options are to increase the mass of fluid within a fixed container, or to decrease the size of a container with a fixed mass of fluid. Either would increase the pressure of the fluid.
Practically speaking, this means you can either:
  • Pump the fluid into a fixed volume container, the more fluid you pump in the higher the pressure (requires a high-static-pressure pump). This might be the more common method because it can support continuous flow.
  • Compress the fluid in a container which can change size, like for example a piston-cylinder combination.
I can understand the principle. But, problem is what kind of machinery can perform at such low temperature.
What low temperature? Liquid water is not a very low temperature.
Posted June 2024 - 15 years after starting this class. I have learned a whole lot. To get to the short course on making your stock car, late model, hobby stock E-mod handle, look at the index below. Read all posts on Roll Center, Jacking effect and Why does car drive straight to the wall when I gas it? Also read You really have two race cars. This will cover 90% of problems you have. Simply put, the car pushes going in and is loose coming out. You do not have enuff downforce on the right...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
