Can Triple Integrals Be Solved in Multiple Ways?
7 replies · 3K views · last reply
rado5
Handwritten work solving a triple integral of z squared over region D in spherical coordinates, with sketches of two intersecting spheres and a cross-section, and labelled subregions D1 to D4 with their r, theta and phi ranges.
  • Handwritten work solving a triple integral of z squared over region D in spherical coordinates, with sketches of two intersecting spheres and split regions D1 to D4 with their r, theta and phi ranges.
[itex]x^2+ y^2+ z^2= 2az[/itex] when [itex]x^2+ y^2+ z^2- 2az= 0[/itex]. We can complete the square by adding [itex]a^2[/itex] to both sides: [itex]x^2+ y^2+ z^2- 2az+ a^2= x^2+ y^2+ (z- a)^2= a^2[/itex]. That is a sphere with center at (0, 0, a) and radius a. [itex]x^2+ y^2+ z^2= a^2[/itex] is, of course, a sphere with center at (0 0, 0) and radius a. The two spheres intersect when [itex](z- a)^2 - z^2= z^2- 2az+ a^2- z^2= a^2- 2az= 0[/itex] or [itex]z= a/2[/itex], in which case [itex]x^2+ y^2+ z^2= x^2+ y^2+ a^2/4= a^2[/itex] or [itex]x^2+ y^2= 3a^2/4[/itex]. That is, the intersection is a circle in the z= a/2 plane with center at (0, 0, a/2) and radius [itex]a\sqrt{3}/2[/itex].
In terms of spherical coordinates, each point on that circle of intersection has [itex]\rho= a[/itex] and [itex]\theta= arcsin(\sqrt{3}/2)= \pi/6[/itex]
The integral, then, should be done in two parts: For the first, [itex]\theta[/itex] goes from 0 to [itex]\pi/6[/itex] and, for each [itex]\theta[/itex], [itex]\rho[/itex] goes to the "upper sphere", [math]x^2+ y^2+ z^2= a^2[/math], from 0 to a.
For the second part, [itex]\theta[/itex] goes from [itex]\pi/6[/itex] to [itex]\pi/2[/itex] and, for each [itex]\theta[/itex], [itex]\rho[/itex] goes from 0 to the "lower" sphere [itex]x^2+ y^2+ z^2= 2az[/itex] which in polar coordinates is [itex]\rho^2= 2a\rho cos(\theta)[/itex]. That is, for each [itex]\theta[/itex], [itex]\rho[/itex] goes from 0 to [itex]2a cos(\theta)[/itex]. (Note that when [itex]\theta= \pi/6[/itex], [itex]cos(\theta)= 1/2[/itex] so that [itex]\rho= a[/itex].)
[itex]\phi[/itex] goes from 0 to [itex]2\pi[/itex] for both integrals.
(In order to be consistent with the original post, I have used "engineering" notation of spherical coordinates in which [itex]\theta[/itex] is the "co-latitude" and [itex]\phi[/itex] is the "longitude" rather than "mathematics" notation in which the two Greek letters are reversed. I have used [itex]\rho[/itex] rather than "r" because that is the convention in either system.)
Divide the integral in 2 parts:
[tex]0< \varphi < \pi/3[/tex] where [tex]\rho = a[/tex]
and
[tex]\pi/3< \varphi < \pi[/tex] where [tex]\rho = a\:sen2\varphi[/tex]
[tex]z = \rho cos\varphi[/tex]
So you solve
[tex]\int_{0}^{2\pi} \int_{0}^{\pi/3} \int_{0}^{a} \rho^2 (cos\varphi)^2 \rho^2 sen \varphi \: d\rho \: d\varphi\:d\theta <br /> +<br /> \int_{0}^{2\pi} \int_{\pi/3}^{\pi} \int_{0}^{2asen2\varphi} \rho^2 (cos\varphi)^2 \rho^2 sen \varphi \: d\rho \: d\varphi\:d\theta [/tex]
and
So you solve
Only the firt part, if I didn't make mistakes:
[tex]=\int_{0}^{2\pi} \int_{0}^{\pi/3} \int_{0}^{a} \rho^2 (cos\varphi)^2 \rho^2 sen \varphi \: d\rho \: d\varphi\:d\theta[/tex]
[tex]=\int_{0}^{2\pi} \int_{0}^{\pi/3} \left [ \frac{\rho^5}{5} (cos\varphi)^2 sen \varphi \: \right ]_0^a \: d\varphi\:d\theta[/tex]
[tex]=\frac{ a^5 }{5} \int_{0}^{2\pi} \int_{0}^{\pi/3}(cos\varphi)^2 sen \varphi \: \: d\varphi\:d\theta[/tex]
[tex]=\frac{ a^5 }{5} \int_{0}^{2\pi} \left[ \frac{-(cos\varphi)^3}{3} \: \right]_0^{\pi/3} \: d\theta[/tex][tex]=\frac{ a^5 }{5} \int_{0}^{2\pi} \left[ -\frac{3\sqrt3}{24} +\frac{1}{3} \: \right] \: d\theta[/tex][tex]=\frac{ a^5 }{5} \left( \frac{8-3\sqrt3}{24} \right) \int_{0}^{2\pi}\: d\theta[/tex]
[tex]=2\pi \frac{ a^5 }{5} \left( \frac{8-3\sqrt3}{24} \right)[/tex]
Other part
[tex]=\int_{0}^{2\pi} \int_{\pi/3}^{\pi} \int_{0}^{2asen \varphi} \rho^2 (cos\varphi)^2 \rho^2 sen \varphi \: d\rho \: d\varphi\:d\theta[/tex]
[tex]=\int_{0}^{2\pi} \int_{\pi/3}^{\pi} \left [ \frac{\rho^5}{5} (cos\varphi)^2 sen \varphi \: \right ]_{0}^{2asen \varphi} d\rho \: d\varphi\:d\theta[/tex]
[tex]=\frac{32a^5}{5}\int_{0}^{2\pi} \int_{\pi/3}^{\pi} \left (cos\varphi)^2 ( sen \varphi)^6 \: d\varphi\:d\theta[/tex]
[tex]=\frac{32a^5}{5}\int_{0}^{2\pi} \int_{\pi/3}^{\pi} \left (( sen \varphi)^6-( sen \varphi)^8) \: d\varphi\:d\theta[/tex]
Now have fun solving sine power eight :)
Dear HallsofIvy,
Thank you very much for your help. Yes my solution was wrong. At the end of my book the answer is [tex]\frac{59 \pi a^{5}}{480}[/tex] and when I solved it with your method I got the correct answer. I was actually wrong about the ranges!
Dear Quinzio,
I used HallsofIvy's method and I could easily solve it!
