xxChrisxx said:
If you can't measure it, it may as well not exist.
Chris, what I'm trying to avoid here is an accidental violation of conservation of energy and to make sure we address the meat of the OP's question. If a turbine on the side of the road generates 100W and of that, 50W is stolen from the car and 50W would have been dissipated anyway, that's 50W added to the car's engine load. If the engine is running at 30,000W of output, then an immeasurable 0.17% has been added to the load of the engine. You can't say that because it is too small to measure, it can be ignored because it isn't the fraction of the car's load that matters, it's the useful power and efficiency of the turbine that matters.
From the point of view of the turbine, this essentially works out to being a 67% efficient (33% efficient, but half of the output would have been wasted anyway) gas engine driving a fan, which drives a wind turbine. Now if you're the turnpike commission and you're just looking for a sneaky way to increase your rates by a tenth of a penny a mile, that's fine, but this isn't completely free (recovered) energy.
If we must insist that the effect can't just be ignored that it's critical to determine how far away from the road/car the turbines are. At what point do we say the car is in free stream?
But that's the point - by definition, if the car is in free stream, the turbines are getting no wind from it.
The only way there could be a net savings here is if building and running the turbine is cheaper than running wires out to whatever road sign the turbine powers. Then it could end up cheaper for the drivers.
All that said, I'm pretty sure the OP is more interested in the aerodynamics - I just haven't had a chance to go into a lot of detail...
Consider a car drafting another car. The trailing car is being pulled forward by the lead car because there is an area of low pressure between the cars. But the lead car can be said to be "pushed" because the area of low pressure is smaller than if the trail car weren't there. If the trail car were off to the side, the drafting effect is reduced, but still present. If you instead put an obstruction off to the side of the road, the air behind the car is no longer able to follow the car and the area of low pressure behind the car is increased: that's increased pressure drag.
Now, for my thumb-wag calculation above, I assumed that half of the energy being absorbed by the turbine would have been dissipated anyway. I'm not really sure if that's true. I would think that some of it would have been dissipated anyway because the energy dissipates by rubbing together air molecules if nothing else is there, so you're dissipating the energy with a turbine before it can dissipate by rubbing air molecules together. But there
has to be an increase in drag, because you're pulling the wake of the car away from the car, increasing the size of the low pressure area and decreasing its pressure.
