Can you just give me a hint for how to solve this problem?
  • Thread starter HAF
In summary: The way I would do it basically uses 2 equations and 2 unknowns: ## r ## and a distance ## s ## from the origin to where the line ## x=0 ## intersects the top circle of radius ##r ##. It's fairly straightforward to write two equations with ## r ## and ## s ##. The one equation is very simple, and the second uses the...r = 1.0ms = 0.5m
HAF
58
Mentor note = moved to homework hence no template
Good evening everyone. I have a problem with solving this problem. I just don't know where to start. Can you please just "bounce" me somehow?
The radius of the big circle is 1m. What is the radius of the small ones?
The only thing I found out is that the diagonal of the small square is 1m. Nothing else.
Can you help me please?
Thank You
Thank You
I don't think it is correct to say that the diagonal of any in this diagram square is 1. I suggest that you label the picture with what you know already. For example, choose one quadrant containing a small circle and label all of the radii of the small circle as having length ##r##. Label the radius of the large circle in that quadrant as having length 1. Now look at the small square formed by the quadrant boundaries and the large square. What is the length of its diagonal?
Likes jedishrfu and HAF
So the diagonal of the square in the middle is not 1m? If you are correct than I'm completely lost. Help me please. Can you give me some hints for solving this problem?
I gave you some hints in my last post.
Likes jedishrfu
Is this thought correct?
You've marked the angle at the top with an arc and a dot. I've never seen that notation. What does it mean?
I'm sorry for that. This is how I mark right angles.
OK, you have a right triangle. One of the sides adjacent to the right angle has length r. What's the length of the other side (adjacent to the right angle)?
It's also r i think.
So the hypotenuse of that triangle is...
2r^2
I think that's the square of the hypotenuse. :oldwink:
Anyway, when you've got that sorted out, it gives you part of the radius of the large circle. What's the other part? The two parts have to add to 1.
Yeah I'm sorry. 2^1/2r
HAF said:
2^1/2r
Or (√2)r. Click on the big "sigma" sign at the left, above the message box, and you'll get a palette of symbols that you can enter directly. I used parentheses to make clear that the square root applies only to the 2, not to the r.
Now you can "piece together" the radius of the large circle, which equals 1.
Thank You very very much. I don't know why I didn't find it out by myself. I have to practise more.
Thank You guys. You are amazing.
Likes jedishrfu
Did this one get solved yet? I don't see a final answer from the OP @HAF . ## \\ ## The way I would do it basically uses 2 equations and 2 unknowns: ## r ## and a distance ## s ## from the origin to where the line ## x=0 ## intersects the top circle of radius ##r ##. It's fairly straightforward to write two equations with ## r ## and ## s ##. The one equation is very simple, and the second uses the properties of the 45 degree right triangle. ## \\ ## If you just consider one circle of radius ##r ##, the problem can be solved with x and y axes and a circle of radius ##r ## that fits into one quadrant. The distance ## s ## is then along the line ##y=x ##, from the origin to where the line first intersects the circle.
Yeah I solved it. I will definitely use your method also.
I solved it with the right angled triangle.
It's hypotenuse is (√2)r.
(√2)r + r = 1
r= 0,41m
Thank you for your tip Charles.
Likes tnich and Charles Link
(√2)r + r = 1
r= 0,41m
What you did is very similar to how I solved it. The hypotenuse that you computed to be ## \sqrt{2} r ## is what I called ## r+s ##. I saw that ## (r+s) \frac{\sqrt{2}}{2}=r ## because of the 45 degree right triangle. And then ## (r+s)+r=1 ##. Your solution is essentially the same thing, and perhaps a step quicker to the answer.
Likes HAF
Most important thing is that we solved it. :)
Thank You
Likes Charles Link
1. How can I approach solving this problem?
The best way to solve a problem is to break it down into smaller, more manageable steps. Start by identifying the key components of the problem and brainstorming potential solutions for each one. Then, try to combine these solutions to come up with an overall solution for the problem.
2. Can you provide any specific hints or tips for solving this problem?
While every problem is unique, some general tips for problem-solving include being patient and persistent, thinking creatively, and seeking help or advice from others. It may also be helpful to draw diagrams or make a list of variables to better understand the problem.
3. What should I do if I get stuck while trying to solve this problem?
If you encounter difficulties while solving a problem, take a step back and try to identify where you might have gone wrong. It may also be helpful to take a break and come back to the problem with a fresh perspective. Additionally, seeking guidance from a mentor or colleague can often provide valuable insights.
4. How do I know if my solution is correct?
To determine the accuracy of your solution, it is important to test it and check for any errors. This can involve plugging in values or running simulations to see if your solution produces the expected results. It may also be helpful to seek feedback from others to verify your solution.
5. Is there a specific method or approach I should use to solve this problem?
There is no one-size-fits-all method for solving problems, as different problems may require different approaches. However, some commonly used problem-solving techniques include trial and error, brainstorming, and using algorithms or mathematical equations. It is important to choose the method that best suits the specific problem at hand.
