Can the Integral of (x+25)(x/4+6)^7 be Simplified Using Substitution Method?
  • Thread starter percs
  • Tags
    Integral
In summary, the power integral can't be solved because there is an algebra mistake in the substitution.
percs
integral of (x+25)(x/4+6)^7 dxno foiling out the power
i thought mayeb putting it as (x+25)((x/4+6)^2)^3.5 dx
and then sub : u = x^2/16 + 3x +36 and du = x/8 + 3 dx and 8du = x +24 dx
but its x+25 that we got ... so yea
What's wrong with u=x/4+6? Can't you express x+25 in terms of u?
There's a much more obvious substitution that turns the integrand into a sum of monomials. Make the denominator (almost) as simple as possible.
well then du = dx ... umm how could that be correct?
If u = x/4 +6 then du is not equal to dx.
well if u = x/4 +6 then the closest to x+25 is 4u = x+24
sorry 4du = dx
The point is to get rid of all the x. You don't need it to have the form c*u where c is some constant.
i) du isn't equal to dx and ii) how do you know it couldn't work if you haven't tried it?
would i be able to do that with integration by parts?
i did it gives me u = x/4 + 6 and du = dx/4
dont know where to go form there
u = x/4 + 6 is the same as x = 4u - 24. Rewrite the entire integral in terms of u and du.
ok well i get
4* integral (4u-1)((4u-2)/4)^7 du
1/4^6 * integral (4u-1)(4u-2)^7 du
and now I am stuck ... once again -_-
You have:
x/4 + 6 = u (the substitution we did to make the denominator nice)
x + 25 = 4u + 1
dx = 4 du
Use this.
You have an algebra mistake in your substitution. u = x/4 + 6 and x = 4u - 24 mean that
(x+25)(x/4+6)^7 dx = ( 4u -24 + 25) (u)^7 ( 4 du)
ya so i have 4* integral (4u+1)(u^7) du
so its equal to :
4[ (4(x/4+6)^9)/9 + ((x/4+6)^8)/8] + c ?
1. What is an integral substitution?
An integral substitution is a method used in calculus to simplify and solve integrals by substituting a variable or expression with a new one. This is often used when the integrand (the function being integrated) contains a complicated expression that can be simplified with the substitution.
2. How do I know when to use an integral substitution?
There is no exact rule for when to use an integral substitution, but it is often helpful when the integrand contains a complicated expression that can be simplified with the substitution. It is also helpful when the integrand contains a function and its derivative, or when it contains a function raised to a power.
3. What are the steps for performing an integral substitution?
The steps for performing an integral substitution are as follows: 1) Identify the substitution to be made by looking for a function and its derivative, or a function raised to a power. 2) Substitute the new variable or expression into the integral. 3) Rewrite the integral in terms of the new variable or expression. 4) Solve the integral using traditional integration techniques. 5) Substitute the original variable or expression back into the final solution.
4. Can all integrals be solved using an integral substitution?
No, not all integrals can be solved using an integral substitution. Some integrals may require other techniques such as integration by parts or partial fractions. It is important to first try an integral substitution, and if it does not work, then try other methods.
5. Are there any tips for choosing the right substitution?
Choosing the right substitution can be challenging, but there are a few tips that can help. 1) Look for expressions in the integrand that can be simplified with the substitution. 2) Try to choose a substitution that will eliminate or reduce the number of terms in the integrand. 3) Be aware of common substitutions, such as u-substitution for functions and their derivatives, or trigonometric substitutions for expressions involving trigonometric functions.
  • Calculus
