Can't Get Integral To Come Out Right
  • Thread starter Thread starter Meadman23
    Integral
Meadman23
What is ∫r^3/(r^2 + h^2) ^ (3/2)
uv - ∫v du
Using Maxima gives me (r^2 + 2h^2) / sqrt(r^2 + h^2), but when I solve it using integration by parts, I get (3r^2 + 4h^2) / sqrt (r^2 + h^2).
I do:
dv = r(r^2 + h^2) ^ (-3/2)
v = -1/sqrt(r^2 + h^2)
u = r^2
du = 2r dr
Then I plug it into the int. by parts formula.
uv - ∫v du = -r^2/ sqrt (r^2 + h^2) - ∫ - 2r dr / (r^2 + h^2)
And then I integrate once more and I'm left with:
-r^2 / sqrt (r^2 + h^2) + 4*sqrt (r^2 + h^2)
I know that this should work out almost exactly like example 7 from this page, but it just won't. What's going on??
Try a straight u substitution instead of parts. Write your numerator as ##r^2\cdot r\, dr## and let ##u=r^2+h^2##.
Doesn't seem to work.
Letting u = r ^2 + h^2 takes care of r dr but not r^2.
I even tried setting r^2 = u - h^2 , but that doesn't get me anywhere either.
Meadman23 said:
I even tried setting r2 = u - h2 , but that doesn't get me anywhere either.
That should (and does) work !
Break the integrand into the sum/difference of two fractions.
Sure it does. Put ##u - h^2## in for that ##r^2##.
Okay, thanks guys. I split the fraction up into two.
∫u/(2*u^(3/2)) - ∫h^2/(2*u^(3/2)
I wasn't able to get it to come out right until I considered the h^2 as a constant and factored it out along with the 1/2.
1/2∫u/(u^(3/2)) - h^2/2 ∫1/(2*u^(3/2)
Why can I consider h^2 as a constant here? Also, why did integration by parts provide the wrong answer for me??
Well, h is not a function of r, is it ?
I mean, h^2 = u - r^2 which means to me that the value of h^2 is dependent on the value of r. How could it not be?
No you're confusing yourself. u and r^2 are both functions of r, but their difference is not.
Consider this trivial example. Let y= 1 - x^2. Now y is a function of x, obviously. But x^2 is also a function of x.
So if we rearrange this to get 1 = y - x^2, does this mean that "1" is a function of x? No, certainly not.
I might be reaching here but let's see.
I have:
u = h^2 + r^2
and
r^2
u - r^2 = (h^2 + r^2) - r^2 = h^2
Thus, r^2 vanishes and h^2 is no longer of a function of r. Thus, I can factor it out of my integral.
Am I seeing this right?
Hmm, let r = h \sinh t as a change of variable.
