Cant grasp difference between infinitesimal change and macroscopic change
Infinitesimal change in volume, denoted as dV, refers to an extremely small change, often conceptualized as approaching zero, such as 0.0000000001L. In contrast, a large change in volume, represented as delta V, is a more significant difference, like 0.5L. The discussion highlights that infinitesimal changes are used in calculus to analyze rates of change at specific moments, as seen in the example of calculating average speed versus instantaneous speed. The average speed is derived from larger changes (delta x/delta t), while the instantaneous speed requires the derivative (dx/dt), illustrating the distinction between finite and infinitesimal changes in mathematical contexts.
Dars
What does infinitesimal change in V mean? Can someone please illustrate with simple example.
Lecture notes say infinitesimal change in V = dV
And large change in V is delta V.. I don't understand what it means though
Chemistry news on Phys.org
Infitesimal change is something like... change in volume = 0.0000000001L
large change is something like... change in volume = .5L
http://en.wikipedia.org/wiki/Infinitesimal"
In the context of your textbook, was it just referring to magnitude or was it also using that as a way of saying, "change below the limit we need to be concerned with."?
I think this is more of a mathematical question, try and ask the question on the math board (calculus section).
It's like when you try and deduce the average speed of a car, when you know it traveled 10m in 2s, the average speed during those 2 seconds is 5m/s, and that's delta(x)/delta(t). If you want to know the exact speed at one particular moment in time, you need the function of x(t) and derive it, being dx/dt, so the infinitesimal change in position divided by the infinitesimal change in time.
It seems like a simple enough question: what is the solubility of epsom salt in water at 20°C? A graph or table showing how it varies with temperature would be a bonus. But upon searching the internet I have been unable to determine this with confidence. Wikipedia gives the value of 113g/100ml. But other sources disagree and I can't find a definitive source for the information. I even asked chatgpt but it couldn't be sure either. I thought, naively, that this would be easy to look up without...
I was introduced to the Octet Rule recently and make me wonder, why does 8 valence electrons or a full p orbital always make an element inert? What is so special with a full p orbital? Like take Calcium for an example, its outer orbital is filled but its only the s orbital thats filled so its still reactive not so much as the Alkaline metals but still pretty reactive. Can someone explain it to me? Thanks!!
