Capacitance after changing plate distances
  • Thread starter Thread starter exitwound
    Capacitance Plate
The discussion revolves around calculating capacitance changes after altering the distance between capacitor plates. The user correctly combines two capacitors in parallel to find an initial capacitance of 14x10^-6 F and a charge of 3.36x10^-4 C. After reducing the plate distance, the capacitance increases to 21x10^-6 F, resulting in a charge of 5.04x10^-4 C. Confusion arises regarding the problem's wording, leading to uncertainty about whether the questions are identical. The consensus is that the calculations are accurate, with the key takeaway being that halving the separation between plates doubles the capacitance.
exitwound
1. Homework Statement , from my crappy textbook
2. Homework Equations barely explained in my crappy textbook
Q=CV
C=\epsilon A/d
3. The Attempt at a Solution that should be easy but the textbook is crap
Before squeezing:
Simplify the circuit by combining the two capacitors in parallel:
C_{12}=C_1 + C_2
C_{12}=7x10^-6 + 7x10^-6 = 14x10^-6 F
Q=CV
Q=C_{12}V
Q=(14x10^-6)(24)=3.36x10^-4 C
After Squeezing:
C=\epsilon A/d
2C=\epsilon A/(d/2)
C=(7x10^-6)(2)=14x10^-6 F
C_{12}=14x10^-6 + 7x10^-6 = 21x10^-6 F
Q=(21x10^-6)(24)=5.04x10^-4 C
Am I even close?
At this point, I have absolutely no idea what the problem is asking. Did I mention this book is terrible? Aren't both questions asking the exact same thing?? This is ridiculous.
The way it is worded it appears as if a.) and b.) are the same question.
Your work looks right. Remember its asking for an increase so subtract before squeezing value from after squeezing value.
That's what I did, but the answer was wrong.
Anyone? Still no go on this one.
Ah Hmmm... b.) could be a trick question... total charge (+ plus -) is of course zero.
But your calculations are correct for what they find. Parallel capacitances add. Halving the separation doubles the capacitance. That's it.
