Capacitance Decrease w/ Applied DC
The discussion centers on the behavior of a 100uF X5R dielectric ceramic capacitor, which shows a decrease in capacitance to approximately 60uF under a 5V DC bias. This phenomenon occurs due to the dielectric material's permittivity decreasing with applied voltage. Measurements indicate that capacitance can recover to around 80uF when the DC voltage is removed, highlighting the non-constant nature of capacitance in certain dielectrics. The conversation emphasizes that changes in capacitance can result from factors like applied voltage and temperature. Understanding this behavior is crucial for proper capacitor application in circuits.
ColliLJ
I would like to understand why my 100uF 6.3V X5R dielectric ceramic capacitor decreases to ~60uF under a 5V applied DC bias. Can anyone explain the physical phenomenon?
So, you applied 5V to 100uF cap and when you measured its capacitance by some equipment after removing supply it was 60uF. Am I right? Did you measured the capacitance at other voltages too?
Remember that capacitance is a constant and can't be changed normally if the capacitor is being used under the working voltage mentioned for that component.
The decrease in capacitance is while the 5V DC is applied. I can measure the capacitance at 60uF with an applied DC voltage. When I remove the 5V supply (DC Bias = 0V), the measured capacitance goes up to 80uF, which is just barely above the lower limit for the 100uF cap (+/-20%).
The capacitance is not constant! It's a well known phenomenon that some dielectrics decrease in permitivity as a function of an applied DC voltage, or an increase/decrease in temperature, etc. I just wanted to understand the phenomenon.
Very basic question. Consider a 3-terminal device with terminals say A,B,C. Kirchhoff Current Law (KCL) and Kirchhoff Voltage Law (KVL) establish two relationships between the 3 currents entering the terminals and the 3 terminal's voltage pairs respectively. So we have 2 equations in 6 unknowns. To proceed further we need two more (independent) equations in order to solve the circuit the 3-terminal device is connected to (basically one treats such a device as an unbalanced two-port...
Thread 'Weird near-field phenomenon I get in my EM simulation'
I recently made a basic simulation of wire antennas and I am not sure if the near field in my simulation is modeled correctly. One of the things that worry me is the fact that sometimes I see in my simulation "movements" in the near field that seems to be faster than the speed of wave propagation I defined (the speed of light in the simulation). Specifically I see "nodes" of low amplitude in the E field that are quickly "emitted" from the antenna and then slow down as they approach the far...
