The discussion centers on the behavior of a 100uF X5R dielectric ceramic capacitor, which shows a decrease in capacitance to approximately 60uF under a 5V DC bias. This phenomenon occurs due to the dielectric material's permittivity decreasing with applied voltage. Measurements indicate that capacitance can recover to around 80uF when the DC voltage is removed, highlighting the non-constant nature of capacitance in certain dielectrics. The conversation emphasizes that changes in capacitance can result from factors like applied voltage and temperature. Understanding this behavior is crucial for proper capacitor application in circuits.
#1
ColliLJ
I would like to understand why my 100uF 6.3V X5R dielectric ceramic capacitor decreases to ~60uF under a 5V applied DC bias. Can anyone explain the physical phenomenon?
So, you applied 5V to 100uF cap and when you measured its capacitance by some equipment after removing supply it was 60uF. Am I right? Did you measured the capacitance at other voltages too?
#3
ElectroPhysics
115
Remember that capacitance is a constant and can't be changed normally if the capacitor is being used under the working voltage mentioned for that component.
#4
ColliLJ
The decrease in capacitance is while the 5V DC is applied. I can measure the capacitance at 60uF with an applied DC voltage. When I remove the 5V supply (DC Bias = 0V), the measured capacitance goes up to 80uF, which is just barely above the lower limit for the 100uF cap (+/-20%).
The capacitance is not constant! It's a well known phenomenon that some dielectrics decrease in permitivity as a function of an applied DC voltage, or an increase/decrease in temperature, etc. I just wanted to understand the phenomenon.
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
Hi Guys
We are a bunch a mechanical engineers trying to build a simple electromagnet. Our design is based on a very similar magnet. However, our version is about 10 times less magnetic and we are wondering why. Our coil has exactly same length, same number of layers and turns.
What is possibly wrong? PIN and bracket are made of iron and are in electrical contact, exactly like the reference design.
Any help will be appreciated.
Thanks.
edit: even same wire diameter and coil was wounded by a...
