Capacitance Discharge Ignition System
A user is building a capacitance discharge ignition (CDI) system for flame speed measurements and requires a capacitor rated at 5 nF and 10 kV, along with a high-voltage diode and relays. Another participant questions the component values, noting that typical CDI systems generate high voltage through a spark coil, which usually requires lower voltage ratings for diodes and relays, around 600V. The discussion highlights the importance of understanding component specifications in CDI systems. Participants share insights on sourcing components and clarify voltage requirements for effective system design. The conversation emphasizes the need for accurate component selection in high-voltage applications.
jaap de vries
Dear friends,
I am building a CDI system to ignite fuel mixtures in a pressure chamber for flame speed measurements.
I need a capacitor of about 5 nF, but it should hold up to 10 kV.
Any suggestions on where I can get those. I also need a diode (rectifier) for 10 kV. Also I need high voltage relays.
Jaap
Ummmm.
Where are you getting you component values from?
Normal CDI, the spark coil generates the HV (10Kv to 30Kv).
With a standard spark coil 100v to 350v on C of 1uf should give about that output range.
So your diodes and relays only have to rated for about 600v.
Thread 'Weird near-field phenomenon I get in my EM simulation'
I recently made a basic simulation of wire antennas and I am not sure if the near field in my simulation is modeled correctly. One of the things that worry me is the fact that sometimes I see in my simulation "movements" in the near field that seems to be faster than the speed of wave propagation I defined (the speed of light in the simulation). Specifically I see "nodes" of low amplitude in the E field that are quickly "emitted" from the antenna and then slow down as they approach the far...
Hello dear reader, a brief introduction: Some 4 years ago someone started developing health related issues, apparently due to exposure to RF & ELF related frequencies and/or fields (Magnetic). This is currently becoming known as EHS. (Electromagnetic hypersensitivity is a claimed sensitivity to electromagnetic fields, to which adverse symptoms are attributed.) She experiences a deep burning sensation throughout her entire body, leaving her in pain and exhausted after a pulse has occurred...
