Calculating Voltage Across Capacitor: EMF and Internal Resistance Question"
  • Thread starter Thread starter coffeem
    Capacitance
The discussion focuses on calculating the voltage across a capacitor connected to a cell with EMF and internal resistance. To derive the voltage expression, it is essential to consider the relationships between voltage, charge, and current in the circuit. The voltage across the capacitor can be expressed as V = E - Ir, while the charge on the capacitor relates to its capacitance and voltage. For the specific case of a 5000uF capacitor reaching 73V in 10ms and tending towards 150V, simultaneous equations must be solved to find the cell's EMF and internal resistance. Understanding the correct signs and relationships in the equations is crucial for accurate calculations.
coffeem
At time t=0, a cell of EMF E and internal resistance r is connected to the capacitor of Capacitance C.
i) Derive an expression for the voltage across the capacitor at subsequent times.
ii) If the capacitance is 5000uF and the voltage across the capacitor reaches 73 V at a time 10ms after connection, before tending towards a steady value of 150V, what are the values of the cell's EMF and internal resistance?
E = V - IR?
I am unsure about part i. I know for the second part i will have to solve a simultaneous equation... However I can't get part i.
Any advice would be greatly appreciated! Thanks
You can consider the cell with internal resistance as a perfect cell, which has no internal resistance, in series with a resistor whose resistance = r. Then what do you have for voltage u, charge q, and current i?
Umm I really don't know.
V = e - Ir
can you give me some more adivce. I have the answer but have no idea how the question askerer has got there! thanks
In these kinds of questions, we must be very careful in considering v, i and q, as it will affect the signs.
Consider the circuit like in the picture. Choose q as the charge of the upper plate. Choose the (+) direction of current i as in the picture. Consider the potential difference between 2 points A and B:
_ For the battery: V_{AB}=e-ir
_ For the capacitor: V_{AB}=q/C
_ Because the current i is "coming into" the upper plate: i=dq/dt
From here, you can solve for V_{AB}. Note that if you choose q and i the way around, or consider V_{BA} instead, the sign corresponding to each in those equations will change.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
