Capacitor Physics: Calculating Potential at Point P with Charged Cylinders
  • Thread starter Thread starter minifhncc
    Capacitor Physics
The discussion revolves around calculating the electric potential at a point P between two charged cylindrical conductors, one at 0V and the other at 12V, with a specified distance between them. The original poster seeks to understand how to derive a specific potential equation involving logarithmic terms.
  • Participants discuss finding the electric field at point P and how to integrate it to determine the potential. There are inquiries about deriving specific constants in the potential equation, particularly the constant term "6" and the coefficient "2.34".
Some participants have offered guidance on the steps to take, including writing down the electric field form and integrating to find the potential. However, there remains uncertainty regarding the constants involved in the final expression, with multiple interpretations being explored.
Participants are working under the constraints of the problem statement and are attempting to clarify the relationships between the electric field, potential, and the constants that arise from the integration process.
minifhncc
[PLAIN]http://img841.imageshack.us/img841/5497/phys.jpg
Capacitor has two cylinders (conducting), as shown.
Charged 0V on LHS cylinder and 12V on the other one. d=140mm.
Show the potential at P is Vp = 6-2.34ln((140-x)/x)
E=integralE.dA
I got as far as using Vp = VPQ + VPR but I cannot seem to get the constant term 6 or the 2.34... could someone please show me the correct method for doing this?
Thanks
Firstly, you find the total electric field at P. From this result, you calculate the potential at point P (from a to d-a). When you arrive this point, consider conditions given in problem: VL = 0 (x = a) and VR = 12 (x = d-a). Plug these into the potential you just found to determine some constants.
Thanks for your reply. But I can't seem to be able to get this, especially the constant value (ie. 6)... Where does that come from?
Sry for this inconvenience. I will try again.
1/ You should write down the form of electric field caused by a cylinder conductor at point x outside the conductor.
2/ Find total field at point P (beware the sign of RHS field).
3/ Find potential (integrate from a to d-a)
4/ After getting step 3, in the form of V, there is a constant q/2πɛz. This constant contribute with another constant (ln(?)) to be 2 constants in your solution. You will determine it by plugging value V = 12 V at point x = d-a.
Thanks for your reply...
This is where I'm getting stuck :( ... So I should get q/2πɛz = two terms?
Thanks a lot
After step 3, the potential at point P is:
[tex]V = \frac{q}{2 \pi \epsilon_0 z} [\ln \frac{d-x}{x} - \ln \frac{d-a}{a}][/tex]
Now plug V = 12 and x = d-a into this formula, and you will have:
[tex]12 = -2 \frac{q}{2 \pi \epsilon_0 z} \ln \frac{d-a}{a}[/tex]
This will yield constant "6" in your solution.
14K
  • · Replies 27 ·
9K
  • · Replies 20 ·
