Carrying Groceries: Calculate the Work Done
  • Thread starter Thread starter Timmy1221
To calculate the work done while carrying a 7.0-kg bag of groceries 1.2 m above the floor at a constant velocity, one must consider the force applied and the distance moved. The work done can be determined using the formula W = F × d × cos(θ), where F is the force, d is the distance, and θ is the angle between the force and the direction of motion. Since the bag is carried at a constant height, the vertical component of the force does not contribute to the horizontal work done. The discussion emphasizes understanding the direction of the applied force and how to calculate work based on force and distance. Properly applying these concepts will lead to the correct solution for the problem.
Timmy1221
  1. You carry a 7.0-kg bag of groceries 1.2 m above the level floor at a constant velocity of 75 cm/s across a room that is 2.3 m wide. How much work do you do on the bag in the process?
KE=(1/2)(m)(v^2)
I haven't a clue where to start. Any help would be appreciated and thanks!
KE=(1/2)(m)(v^2)
What force do you apply to the bag for the 2.3m? What direction is that force in? How do you calculate work done based on a force and a distance (preferably as a vector equation)?
KE=(1/2)(m)(v^2)
Start off by writing in words the definition of Work Done that you will need here.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
