Catching a glass falling to the ground
4 replies · 2K views · last reply
AirForceOne
A person trips against a table, causing a glass to fall off the edge. An excellent human reaction time is 0.25 seconds. In that time, how far wil the glass fall? Assume that immediately (after 0.25 s has elapsed) begin to acclerate your hand so that you grab the glass when it is 6 in from the floor. What constant acceleration was necessary, and how fast was your hand traveling when you contacted the glass? Assume your hand moved in a straight line.
Diagram of a table edge with a blue glass on top, labelled Initial position of hand with an arrow to a point 1 ft below the table top and 2 ft horizontally from the edge, with the 2 ft vertical distance from that point to the floor marked.
I find the position vector of the hand to be:
Equation for a position vector: r = (a_x t^2 / 2) i + ((a_y t^2 / 2) + 2) j, with components along i and j.
I get the position vector of the glass to be:
Handwritten position vector r = (2)i + (-gt^2/2 + 3)j, with the j component written as a fraction with a negative g t squared numerator over 2, plus 3.
I need to find the time it takes for the glass to fall to y=0.5:
Handwritten working: 0.5 = (-gt^2)/2 + 3, then t = 0.71, then 0.71 - 0.25 = 0.46.
So the hand only has 0.46 seconds to reach the glass. However, when I plug this into the position vector of the hand to find a_x and a_y and find the magnitude of the acceleration, I get like twenty-something ft/s^2 which is far below the correct answer of 241 ft/s^2. What am I doing wrong?!
Equation: (2)i + (0.5)j = (a_x(0.46)^2 / 2) i + (a_y(0.46)^2 / 2 + 2) j
Please help asap!
Good afternoon, Mr. President.
Your equations, sir, with all due respect, made me think I was looking at Wiki.
Keep it simple. Find the time it takes for the glass to be 6 inches from the floor, using distance = 1/2gt^2. Then that time less the reaction time is the time that your hand has to reach the glass, traveling a diagonal distance as found from Pythagorus' theorem.
Warmest regards,
Jay
I agree, keep it simple.
1) How far will the glass fall in 0.25 seconds?
You know the value of gravity (9.81 m/s^2), and you know the time (0.25 seconds). Use the equation:
S[itex]_{y}[/itex] = ut + [itex]\frac{at^2}{2}[/itex]
The second part has already been answered.
Warmest regards,
Jay
But that's what I did...
y=(1/2)gt^2
t=sqrt(2y/g)
=sqrt((2)(2.5)/9.8)
= 0.71
0.71-0.25 = .46...
Diagonal distance=2.5,
y=(1/2)at^2
a=(2y)/(t^2)
=(2*2.5)/(0.46^2)
= 23.63ft/s^2...which is what I got before.
Oh, sure, that's a lot better than all those i's and j's.. But in the USA system, g is not established in units of m/sec^2, but rather, in units of ft/sec^2.
9.8m/sec^2 = appx. 32.2 ft.sec^2.:frown:
