Eliminating Lambda to Solve Question 2(b) of Physics Homework
Cosmossos
Hello ,
Please look at question 2 (b).
http://phstudy.technion.ac.il/~wn114101/hw/wn2010_hw05.pdf
I got that the lagragian is the potential energy (as in part a of the question)
How Do I eliminate the lamda so I can write the U (wave) as requested?
Or In Other word, How do I do b?
thanks
Cosmossos said:
Hello ,
thanks
Quick note: The Lagrangian is not the potential energy. It does have a potential term in it but it is not the potential energy; it is the difference between the kinetic energy and the potential energy.
The problem looks pretty straightforward. If you expand \lambda to the two terms inside the bracket and then combine the two integrals, you should get the form requested.
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
