Celestial mechanics with symplectic integrators
The discussion revolves around understanding the algorithm in a paper on celestial mechanics using symplectic integrators. Key points of confusion include the meaning of the sum from 1 to n in equation 2, the interpretation of n, and the application of exponential operators in the equations. There is uncertainty about the general solution q(t) = exp(tau * F) * q(t-tau) and its relation to dq/dt = Fq. Additionally, the relevance of equation 7 to previous equations is unclear, and there is a need for clarification on the concept of degrees of freedom in this context. Overall, the participant seeks specific guidance to grasp these concepts before their presentation.
Masklin
The problem is that I just don't understand how the algorithm described here in section 2 hangs together... I have to present this on Thursday morning and that sensation of 'I'll never understand this soon enough' is growing ominously.
Equations 2,6,7 and 8 are a mystery to me. I could write them out here but they're already in the paper and without their context it wouldn't help much I think.
Why is there a sum from 1 to n in equation 2? What is n? It doesn't say...
And, how is q(t) = exp(tau * F) * q(t-tau) a general solution to dq/dt = Fq ?
Shouldn't it be q(t) = q(tau) * exp(Fq) ?
How does one knows in which order to apply the exponential operators in equation 6?
Where does equation 7 fit in with anything introduced previously?
My attempt at a solution is asking for help here... I've googled but my questions are far too specific for that to help. =(
Please please help!Masklin
Equ. 2 is an application of the chain rule and then Equ. 1. n is the number of the degrees of freedom.
Degrees of freedom - what does that mean in this context? The dimensionality of x and p, or the number of bodies? Or something else?
The dimension of x.
