Finding the Center of a Central Conic: Ellipse and Hyperbola Formulas
  • Thread starter mattmns
  • Tags
    Center
In summary, the conversation discusses finding the center of a central conic with the equation ax^2 + 2hxy + by^2 + 2gx + 2fy + c = 0 and whether there is an easy formula for both an ellipse and hyperbola. The approach of reducing a conic to standard form through rotation and translation is mentioned. The conversation also includes a discussion on completing the squares of x and y terms separately and how it can be used to find the center of the conic. Another approach using partial derivatives is suggested, but the individual is unsure of how to proceed with this method. Translation is clarified as part of the process. The conversation ends with the suggestion of finding points that satisfy certain conditions
mattmns
1,128
How do I find the center of a central conic with the equation [tex]ax^2 + 2hxy + by^2 + 2gx + 2fy + c = 0[/tex] Is there some easy forumlua for both the ellipse and hyperbola? Thanks!
Do you know how to reduce a conic to standard form through rotation&translation?
I don't remember, but I can use it, and it is in the book I am looking at. Thanks! I will see if I can get it from here, thanks!
Just a quick question, about whether I am doing this correct. Because this thing looks nasty.
I used
[tex]cot(2\theta) = \frac{a-b}{2h} [/tex]
Then got
[tex]sin(\theta) = \frac{h(2cos^2(\theta) - 1)}{(a-b)cos(\theta)} [/tex]
and
[tex]cos(\theta) = \frac{h(1-2sin^2(\theta)}{(a-b)sin(\theta)} [/tex]
Then
[tex] x = x' [ \frac{h(1-2sin^2(\theta)}{(a-b)sin(\theta)} ] - y' [ \frac{h(2cos^2(\theta) - 1)}{(a-b)cos(\theta)} ] [/tex]
[tex] y = x' [ \frac{h(2cos^2(\theta) - 1)}{(a-b)cos(\theta)} ] + y' [ \frac{h(1-2sin^2(\theta)}{(a-b)sin(\theta)} ] [/tex]
Does that look correct so far? And then, ughh, I have to substitue that x and y into the original equation, and then see if I can figure the centers from that? Seems like a pain :cry:
Also, what is translation?
Thanks
Thanks
If you succeed in rotating, you will not have any terms that involve xy products. If you had something of the form
ax^2 + bx + cy^2 + dy + e = 0
you could complete the squares of the x terms and the y terms separately and wind up with something of the form
(x-h)^2/A^2 +or- (y-k)^2/B^2 = 1
which is a ellipse or hyperbola, depending on the sign, centered at (h,k). That's the translation part.
Thanks for the clarification.
I am beginning to think the approach I was trying is not a good one.
Here is what I am trying to prove.
[tex]\phi (x,y) = ax^2 + 2hxy + by^2 + 2gx + 2fy + c = 0[/tex]
for [tex] ab - h^2 \neg 0[/tex] That is: ab - h^2 not equal to 0
Show that the center of the central conic [tex]\phi (x,y) [/tex] is the interesection of the lines [tex] \frac{\partial \phi}{\partial x} = 0 [/tex] and [tex] \frac{\partial \phi}{\partial y} = 0 [/tex]
Do you think the approach I am trying, by first finding the center of the central conic is a good route? Thanks
I think there is a better way. It is easier to visualize for the case of an ellipse. Think about what it means for dy/dx = 0 and dy/dx approaches infinity for an ellipse, and how you might use the location of a pair of points that satisfy either one of those conditions to locate the center of the ellipse. How could you find the points (x,y) that satisfy those conditions? Then relate those points to the zeros of the partial derivatives.
For the hyperbola, consider the same interpretations of dy/dx = 0 and dy/dx approaches infinity. Only one of the two can be satisfied for points on the hyperbola, but all you need is one pair of points that satisfies one of those two conditions to locate the center. You can still show that the intersection of the lines obtained from the partial derivatives is the center of the hyperbola.
That sounds like a great idea, and I tried it, but I did not come up with exactly what I wanted.
I got dy/dx, using implicit differentiation, to be: [tex]\frac{-2ax - 2hy - 2g}{2hx + 2by + 2f}[/tex] So, when dy/dx = 0, then -2ax - 2hy - 2g = 0. You could also say from that, that when dy/dx = 0, then 2ax + 2hy + 2g = 0. Also, when dy/dx = [tex] \infty [/tex] then 2hx + 2by + 2f = 0.
Now, when I did the partial differentiation, I got the same answers, which is why I did not like it.
I got
[tex] \frac{\partial \phi}{\partial x} = 2ax + 2hy + 2g [/tex]
and
[tex] \frac {\partial \phi}{\partial y} = 2hx + 2by + 2f [/tex]
From here I am stuck, I am unsure of really what to do. It seems like it is close, but just not there.
I guess you could say that for the first part, dy/dx = 0, that [tex]y = \frac{-ax - g}{h}[/tex] Which is a line, but from there I am uncertain, other than finding the other line, which is [tex] y = \frac {-hx - f}{b}[/tex]
I got
and
The correspondence between the dy/dx results and the partial derivatives is exactly what you want. Think of any ellipse you can imagine, centered anywhere, with any aspect ration, with axes at any angle of rotation relative to the x-y axes. The solution to [tex]dy/dx = 0[/tex] is a line that will intercept that ellipse at two special points. The solution to [tex]dy/dx = \infty [/tex] is a line that intercepts the ellipse at two other special points. Think about what these points mean, and where these lines must intersect based on the symmetry of an ellipse.
As I said before, you really only need one of these lines and the intercepts with the ellipse to locate its center. Use that fact to help you interpret the same equations for the hyperbola.
I must not being seeing it.
Here is a diagram of the ellipse.
http://img31.echo.cx/img31/8499/diagramellipse13pq.png
There is the line where the slope is 0, and the line where the slope is [tex] \infty[/tex] Now, I can see how you can use it to find the center. But the problem says that the intersection of these two will be the center. [tex] \frac{\partial \phi}{\partial x} and \frac{\partial \phi}{\partial y}[/tex]
Maybe I am misinterpreting something here, but those two are equal to the 0 and infinity lines, which to me intersect up at the top. Now, if you used the infinty line at either point of either of the zero lines, and the zero lines at either point of the infity lines, I can see how that would be the center, but to me that is not what the problem said, which I why I think I am not interpreting something correctly.
Take a look at these example cases created using the graphing feature at
http://www.quickmath.com/
See where the blue lines (partial derivatives) intercept the curves. The horizontal and vertical lines are just to guide your eye to see what is special about these intercepts
Ahh I see, very cool, thanks!
What is the center of a central conic?
The center of a central conic is the point that lies at the intersection of the major and minor axes of the conic. It is also the point where all the diameters of the conic intersect.
How is the center of a central conic determined?
The center of a central conic can be determined by finding the midpoint of the major and minor axes, or by using the equation of the conic and solving for the x and y coordinates of the center.
What is the significance of the center of a central conic?
The center of a central conic is significant because it is the point of symmetry for the conic. This means that any point on one side of the center has a corresponding point on the other side with the same distance from the center.
How does the center of a central conic affect the shape of the conic?
The center of a central conic determines the shape of the conic. If the center is located at the origin, the conic will be a circle. If the center is off-center, the conic will be an ellipse. And if the center is outside the conic, it will be a hyperbola.
Can the center of a central conic be located at a negative coordinate?
Yes, the center of a central conic can have negative coordinates. This will result in a conic that is shifted to a different position on the coordinate plane, but the shape of the conic will remain the same.
  • General Math
  • Linear and Abstract Algebra
