Center of gravity of this body: y = (x^2)/a (rotated about the x-axis)
  • Thread starter Thread starter Heexit
The discussion revolves around calculating the center of gravity for a body defined by the equation y = (x^2)/a when rotated about the x-axis. The proposed solution suggests that the center of gravity is (5/6)*a, although the original poster expresses uncertainty about their approach. Suggestions for improvement include using the formula for the center of mass of a solid of revolution, specifically integrating the volume of disks. There is also a note regarding potential confusion in notation, particularly with the letter 'x' resembling the Greek letter alpha. The conversation emphasizes the importance of clarity in mathematical expressions and proper integration techniques.
Heexit
A homogeneous body is formed by rotating the surfaces in the image around the x-axis (see picture). Determine the location of the center of gravity.
N/A
Hello Physicsforum!
My solution (sorry for not writing it in LaTeX, I don't feel it's necessary since this try was more of a shot in the dark):
The answear should be (5/6)*a
Had no idea of how to go about solving this, so tried using the followin equaiton (I have no idea what W stands for in this case, but it can be switched out for mass/volume/area):
Any suggestions about what could have gone wrong alternatively what I should do instead would be appreciated!
Thanks on beforehand:smile:
W could means weight.
This is a solid of revolution. It looks like you need to use $$\bar X=\frac{\int x~ dV}{\int dV}$$where ##dV## is the volume of a disk of thickness ##dx## and radius ##y##.
Thanks a lot for your help!
Here is my solution (still not in LaTeX!):
Looks OK even though not in LaTeX. Your letter ex in places looks a bit like the Greek letter alpha and that could be confusing.
Likes Heexit, berkeman and MatinSAR
