Center of mass and rotation question
The discussion centers on a physics problem involving two balls connected by a rigid rod rotating about their center of mass. The center of mass was calculated to be 0.24m from the 100g ball, but there is confusion regarding the calculation of linear speed for the 100g ball. It is clarified that while both balls share the same angular velocity, their linear velocities differ based on their respective distances from the center of mass. The main question is to determine the correct speed of the 100g ball relative to the center of mass. Participants are seeking clarification on the calculations involved in finding this speed.
sp3sp2sp
A 100 g ball and a 250 g ball are connected by a 34-cm-long, massless, rigid rod. The balls rotate about their center of mass at 150 rpm .
I solved by first getting the center of mass, then converting rpm into m/s
I treated rigid rod as the x-axis
I assumed that the 100g ball rotates at same speed as 250g ball because they are connected by a rigid rod.
0.1kg(0m)+0.25kg(0.34m) / 0.1kg+0.250kg
= 0.24m = the center of mass around which the 2 balls rotate.
150rpm (1min/60s) 0.34m(pi)
=2.7m/s = wrong for some reason
thanks for any help!
What is the question in the homework problem?
The balls rotate with the same angular velocity, but the velocity relative to the center of mass depends both on the angular velocity and the (different) distance to the center of mass.
wow i can't believe i forgot to include that..sorry. The question is: what is the speed of the 100g ball?
That is probably relative to the center of mass.
sp3sp2sp said:
150rpm (1min/60s) 0.34m(pi)=2.7m/s
I don't understand this calculation. Please fill in the details.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
