Center of Mass bounded by Equations
The discussion revolves around finding the center of mass for the area between the curves defined by the equations y1=2sin(3/2x) and y2=(1/3)x, intersecting at approximately x=1.88. The user initially calculated the vertical center of mass using the area between the curves, but faced challenges in determining the differential mass (dm) when y exceeds (1/3)(a). Suggestions were made to find the vertical center of each differential strip as (y1+y2)/2 and to integrate this over the interval [0, a] for the weighted average. The importance of using the correct midpoint formula and ensuring the weighted sum of positions for each strip was emphasized. The final approach involves integrating the new y-position of the center of mass with the previously established dm expression.
nat1
I have equations that are y1= 2sin(\frac{3}{2}x) and y2= \frac{1}{3}x the point where they intersect is called "a" (about x≈1.88). Find the center of mass where M is the total mass of the object.
xcm= \frac{1}{M}∫x dM
I found the vertical center of mass by using the area between the curves and setting
dm= density*thickness*(y1 - y2)dx
and setting
M=density*thickness*area
area is between the curves. As I am trying to find the CM along the horizontial of the object i can't figure out dm because when y>\frac{1}{3}(a) y1 has two values, how can i correct for this? my first thought is to rearrange the equations to find f(y)=x and subtract the x values but i still run into the same problem.
Nat
and setting
Nat
You should be able to find both the x and y centers of mass by integrating along the x-axis. Consider that your dm "strips" bounded by y2 and y1 in addition to having a position along the x-axis, will also each have a vertical center where the actual center of mass of that strip lies.
im still not sure i understand %100:
So each dm will have a vertical center of (y1-y2)/2 and this is where the center of mass for each strip lies. so then i would just need to take the average of these over the interval [0, a]
Thanks!
Thanks!
Careful, the midpoint between two numbers y1 and y2 is (y1 + y2)/2. And you still need to do the weighted sum of these positions (the dm strips all have different masses).
Good luck!
Good luck!
oops, my fault! i would do the integral of \frac{1}{area between the curves}∫(y1+y2)/2dx is this right? assuming M and dm are the same as above.
(y1 + y2)/2 gives you the y-position of the cm for the given strip. The strip's mass is still dm, for which you previously obtained a formula. The ycm of the object is still given by the weighted sum:
##y_{cm} = \frac{1}{M} \int y\;dm ##
where you use your new y-position in place of y, and use your dm expression as before.
